Question:
The analog output model of the light convergent reflective type Optical Sensor B5W-LB has a variable resister. Can it adjust the sensor’s sensitivity?
Answer:
You should not alter the variable resister position, which is set. Otherwise, the sensor will not meet Omron’s guaranteed product specifications.
Explanation:
This variable resistor is used only for our internal inspection. It would be best if you did not alter its position, which the factory sets. Otherwise, the sensor will not meet Omron’s guaranteed product specifications.
Instead, set a threshold level for your specific application using actual objects to be sensed.
Product category
Sensors Light Convergent Reflective Sensors/Diffuse Reflective Sensors
Classification
Usage, Applications
Related keywords
Optical Sensor
Light Convergent Reflective Type
Sensor
Sensitivity Adjuster
Variable Resistor
B5W-LB
Please visit the link below to see this product line on the Digi-Key website
Optical Sensors | Digi-Key Electronics
