Can the surface mount (SMD) type DIP switch be manually soldered?
Question:
Block
Answer:
Hand soldering is possible with our surface mount type A6SN. The recommended conditions for each model are listed below. Please pay attention to the iron tip temperature, heating time, and scattering of flux.
Block
Explanation:
Omron’s surface mount type A6SN can be hand-soldered. Please refer to the conditions below, and be sure not to allow flux to adhere to the switch or to scatter.
Please note that for other surface mount types, hand soldering is not recommended.
Block
For manual soldering, do not solder the switch more than twice, including rectification soldering, and only solder once for A6TN and A6SN. An interval of five minutes is required between the first and second soldering.
Product category
Switches DIP Switches
Classification
Usage, Applications
Related keywords
Setting Switch
DIP Switch
Surface Mount
Manual Soldering
Soldering Temperature
A6T
A6E-N
A6D
A6TN
A6H
A6HF
A6S-H
A6SN
Block
Please visit the link below to see this product category on the Digi-Key website
Switches | DigiKey Electronics
https://components.omron.com/us-en/faq/switches/FAQE20088
