Before you begin soldering your SDF Series thermal cutoffs from Cantherm, we recommend familiarizing yourself with the parts’ manufacturer datasheet. There is an important caution notice to take note of before undertaking your board assembly process.
Confirmed by Cantherm: in general Cantherm does not suggest soldering the part due to the nature of the device. So no soldering recommendations are provided.
If you are looking for soldering specs in terms of wave soldering, these are not compatible period and they will most likely prematurely activate.
We suggest checking out our post: Correct Thermal Cutoff Installation
Applicable part numbers
SDF DF066S
SDF DF072S
SDF DF077S
SDF DF084S
SDF DF091S
SDF DF098S
SDF DF100S
SDF DF104S
SDF DF110S
SDF DF119S
SDF DF128S
SDF DF141S
SDF DF144S
SDF DF152S
SDF DF170S
SDF DF184S
SDF DF192S
SDF DF216S
SDF DF220S
SDF DF228S
SDF DF240S
317-1123-ND
317-1124-ND
317-1125-ND
317-1126-ND
317-1127-ND
317-1128-ND
317-1129-ND
317-1130-ND
317-1131-ND
317-1132-ND
317-1133-ND
317-1134-ND
317-1135-ND
317-1136-ND
317-1137-ND
317-1138-ND
317-1139-ND
317-1140-ND
317-1143-ND
317-1141-ND
317-1142-ND
