It is important to review the datasheet of an AC fan upon ordering to see if there is an external capacitor requirement for the fan to operate. Impeller fans will almost always require an external capacitor, which may or may not be included with the fan purchase.
EBM Papst fans R4E400-AP15-10 and R4E355-AN09-10 do not come with capacitors. This most likely is the case for all fans within similar series.
Please see the manufacturer response below:
“Correct, these fans do not come with a capacitor. I’ve listed a wet metal case option for each but the customer can use a different capacitor as long as it is rated for at least 220V (higher V is OK) and the appropriate uF.”
Note:
*Fully discharge the capacitors before working on a device, they store power during and after unit is off and supply is disconnected.
*If an AC fan has 4-wires (3+ground), the capacitor is likely mounted external to the fan. If the capacitor is fan mounted (internal), then this would typically be a 2 or 3-wire fan.
Motorized impeller fan R4E400-AP15-10
Capacitor Option: 450-20-0034
Motorized impeller fan R4E355-AN09-10
Capacitor Option: 450-20-0033
Our website “Features” filter will usually list if the capacitor is included:
710-00-0042 is the optional boot for either/both:
Optional accessory inlet ring is not included:
54476-2-4013 inlet ring for R4E400AP1510
35560-2-4013 inlet ring for R4E355-AN09-10
DigiKey Selection:
Click here for all AC Fans
Click here for fan capacitors and caps
Click here for electrolytic capacitor selection
Click here for film capacitor selection - it may help to search within results ‘‘fan’’ for most popular:
See also:
Capacitor for EBM-Papst Fan D2E097-CB11-32
Reducing speed of a EBM-Papst centrifugal blower fan
Wiring Capacitor for Mechatronics Fan UF300BNA 12-H1C2A
Fan W3G200-HD23-10 - Operate mode
Summary
381-2607-ND
381-2610-ND
381-2591-ND
381-2589-ND
381-2612-ND
381-2618-ND
381-2622-ND
381-2623-ND
381-2624-ND
381-2613-ND
381-2615-ND
381-2621-ND
381-2627-ND
381-2631-ND
381-2628-ND
381-450-21-0027-ND
381-450-21-0031-ND
381-2611-ND
381-2614-ND
381-2619-ND
381-2620-ND
381-2625-ND
381-450-21-0020-ND
381-2632-ND
381-450-21-0033-ND
381-2590-ND
381-2617-ND
381-450-21-0030-ND
381-450-21-0028-ND
381-450-21-0018-ND
381-450-21-0034-ND
381-450-21-0017-ND
381-2626-ND
381-2608-ND
381-450-21-0023-ND
381-2609-ND
381-450-21-0021-ND
381-450-21-0029-ND
381-450-21-0024-ND
381-450-21-0019-ND
381-450-21-0026-ND
381-2629-ND
381-450-21-0022-ND
381-2475-ND
2266-2168-4-7320-ND,381-2630-ND
381-2598-ND
381-2597-ND
2266-450-20-0017-ND,381-2592-ND
2266-450-20-0019-ND,381-2474-ND
381-2594-ND
381-2605-ND
381-2606-ND
381-2604-ND
2266-450-20-0029-ND,381-2602-ND
2266-450-20-0030-ND,381-2603-ND
381-2593-ND
450-20-0048-ND
450-20-0039-ND
450-20-0040-ND
450-20-0013-ND
66785-4-7320-ND
381-2616-ND
381-2600-ND
381-2599-ND
381-2596-ND
381-2588-ND
2266-450-20-0021-ND,381-2595-ND
2266-450-20-0028-ND,381-2601-ND
68462-4-7320
99284-4-7320
710-00-0042
66788-4-7320
99286-4-7320
2151-4-7320
2160-4-7320
2161-4-7320
2162-4-7320
99287-4-7320
2101-4-7320
2159-4-7320
2165-4-7320
2169-4-7320
2166-4-7320
450-21-0027
450-21-0031
99285-4-7320
2100-4-7320
2155-4-7320
2156-4-7320
2163-4-7320
450-21-0020
2170-4-7320
450-21-0033
30457-4-7320
2103-4-7320
450-21-0030
450-21-0028
450-21-0018
450-21-0034
450-21-0017
2164-4-7320
99282-4-7320
450-21-0023
99283-4-7320
450-21-0021
450-21-0029
450-21-0024
450-21-0019
450-21-0026
2167-4-7320
450-21-0022
450-20-0022
2168-4-7320
450-20-0025
450-20-0024
450-20-0017
450-20-0019
450-20-0020
450-20-0033
450-20-0034
450-20-0031
450-20-0029
450-20-0030
450-20-0018
450-20-0048
450-20-0039
450-20-0040
450-20-0013
66785-4-7320
2102-4-7320
450-20-0027
450-20-0026
450-20-0023
450-20-0148
450-20-0021
450-20-0028
381-2591-ND
710-00-0042
381-2591
710-00-0042-NDR
710000042
710-00-0042-ND
381-2701-ND
1570-1293-ND
1570-1294-ND
1570-1295-ND
1570-1289-ND
1570-1292-ND
1053-1804-ND
1053-1806-ND
381-2984-ND
1053-1701-ND
1053-1702-ND
381-3041-ND
1053-1703-ND
1053-1630-ND
1053-1631-ND
381-2924-ND
1053-1632-ND
381-2908-ND
1053-1633-ND
381-3035-ND
1570-1291-ND
381-3040-ND
1570-1290-ND
381-2387-ND
381-2979-ND
381-2388-ND
381-3039-ND
381-3168-ND
381-2506-ND
1688-1891-ND
1688-1025-ND
1688-1023-ND
1688-109-1106-ND
1688-1024-ND
1688-2024-ND
381-2519-ND
381-2907-ND
381-3166-ND
1688-1026-ND
2266-35560-2-4013-ND,35560-2-4013-ND
2266-63071-2-4013-ND,63071-2-4013-ND
28000-2-4013-ND
63072-2-4013-ND
96120-2-4013-ND
25075-2-4013-ND
40070-2-4013-ND
35680-2-4013-ND
45080-2-4013-ND
25080-2-4013-ND
35500-2-4013-ND
1053-1808-ND
9569-2-4013-ND
25002-2-4013-ND
1053-1805-ND
51163-2-4037-ND
51164-2-4037-ND
51176-2-4037-ND
51165-2-4037-ND
51161-2-4037-ND
51166-2-4037-ND
51171-2-4037-ND
51175-2-4037-ND
51173-2-4037-ND
51172-2-4037-ND
51162-2-4037-ND
381-3167-ND
IR/265503-ND
IR/265499-ND
IR/265501-ND
IR/265497-ND
IR/265498-ND
IR/265505-ND
IR/265504-ND
IR/265502-ND
IR/265500-ND
52542-2-4037-ND
52543-2-4037-ND
45075-2-4013-ND
1688-2004-ND
109-1073H-ND
1688-2003-ND
109-1081H-ND
96360-2-4013
IR-250
IR-318A
IR-360A
IR-133
IR-225
DR133D
DR22025D
54476-2-4013
DR250A
DR318A
96359-2-4013
DR360A
DR190A
DR220A
35561-2-4013
DR225A
31051-2-4013
DR400A
9576-2-4013
IR-220
96358-2-4013
IR-190
9566-2-4013
51357-2-4013
9609-2-4013
9621-2-4013
9614-2-4013
9588-2-4013
109-1069
109-1134
109-1073
109-1106
109-1081
109-1080
LZ212
31050-2-4013
9597-2-4013
109-1135
35560-2-4013
63071-2-4013
28000-2-4013
63072-2-4013
96120-2-4013
25075-2-4013
40070-2-4013
35680-2-4013
45080-2-4013
25080-2-4013
35500-2-4013
DR250D
9569-2-4013
25002-2-4013
DR1719D
51163-2-4037
51164-2-4037
51176-2-4037
51165-2-4037
51161-2-4037
51166-2-4037
51171-2-4037
51175-2-4037
51173-2-4037
51172-2-4037
51162-2-4037
9607-2-4013
IR/265503
IR/265499
IR/265501
IR/265497
IR/265498
IR/265505
IR/265504
IR/265502
IR/265500
52542-2-4037
52543-2-4037
45075-2-4013
109-1134H
109-1073H
109-1135H
109-1081H
1053-1628-ND
381-1110-ND
381-2555-ND
381-2556-ND
1053-1599-ND
381-2406-ND
381-2549-ND
381-3524-ND
381-2559-ND
381-3502-ND
381-3500-ND
381-3117-ND
381-3499-ND
381-3178-ND
381-2547-ND
381-3526-ND
381-3123-ND
381-3493-ND
381-3557-ND
1570-1184-ND
1570-1271-ND
2266-R2E220-AD19-11-ND,381-3514-ND
381-3121-ND
381-2544-ND
381-3112-ND
381-3507-ND
1053-1693-ND
381-3534-ND
R2E175-AC79-22-ND
381-3496-ND
381-3503-ND
381-3508-ND
1053-1695-ND
381-3491-ND
381-3548-ND
381-3531-ND
1053-1698-ND
381-3552-ND
381-2405-ND
381-3527-ND
381-3517-ND
R4E400-AP15-10-ND
381-3554-ND
1053-1782-ND
1053-1785-ND
1570-1847-ND
1570-1194-ND
1570-1185-ND
1570-1189-ND
1570-1195-ND
381-3116-ND
381-3532-ND
1570-1180-ND
1570-1188-ND
381-3497-ND
381-3558-ND
381-1109-ND
381-2782-ND
381-2785-ND
381-2546-ND
381-2545-ND
381-2870-ND
381-2787-ND
2266-R3G190-RD45-03-ND,381-2788-ND
381-3555-ND
1570-1182-ND
381-3537-ND
381-3510-ND
1570-1193-ND
1570-1196-ND
381-2710-ND
381-2783-ND
381-3512-ND
381-3528-ND
2266-R2E225-RA92-20-ND,381-2786-ND
2266-R2E175-AC77-18-ND,381-2543-ND
381-3113-ND
381-3511-ND
1053-1694-ND
381-3505-ND
381-3115-ND
381-3533-ND
381-3513-ND
381-2548-ND
381-3522-ND
2266-R2E225-AT51-05-ND,381-3518-ND
381-3120-ND
381-3529-ND
2266-R3G220-RD53-03-ND,381-2791-ND
381-2793-ND
381-2795-ND
1570-1183-ND
1570-1179-ND
1570-1846-ND
1570-1186-ND
1053-1624-ND
1053-OAB22599-22-1-ND
381-3535-ND
2266-R2E190-RA26-20-ND,381-2781-ND
1570-1197-ND
1570-1198-ND
381-3506-ND
381-3504-ND
381-3540-ND
381-3494-ND
381-3539-ND
381-3501-ND
381-3547-ND
381-3515-ND
381-3536-ND
381-3495-ND
381-3498-ND
1053-1697-ND
381-3523-ND
381-3520-ND
381-3546-ND
2266-R2E225-BD92-36-ND,381-3525-ND
1570-1202-ND
1570-1203-ND
381-3490-ND
381-3551-ND
381-3549-ND
2266-R2E225-BA47-09-ND,381-3521-ND
1570-1204-ND
381-3541-ND
381-2659-ND
381-2789-ND
381-3530-ND
381-2794-ND
381-3556-ND
381-3543-ND
381-3542-ND
1053-1784-ND
1570-1837-ND
1570-1181-ND
1570-1848-ND
1570-1187-ND
1053-1627-ND
381-3122-ND
1570-1270-ND
1570-1190-ND
1570-1191-ND
1570-1866-ND
1570-1201-ND
1570-1867-ND
2266-R4E250-AB01-25-ND,381-2657-ND
2266-W2D250-CH12-14-ND,381-3138-ND
381-3051-ND
381-2792-ND
603-GTB019BUA07R-VE1-ND
1053-1781-ND
1053-1783-ND
UF133(91)APA23-H1S2A-ND
1570-1854-ND
1570-1178-ND
1053-1786-ND
381-2402-ND
1053-1625-ND
1053-1787-ND
1053-1788-ND
1053-1789-ND
1053-1790-ND
1053-1626-ND
2266-R2E190-AO26-25-ND,381-2401-ND
1570-1856-ND
UF225(69)APA23-H1C2A-ND
UF225(85)APA23-H1C2A-ND
1570-1192-ND
381-2784-ND
1570-1858-ND
381-2868-ND
2266-R2E220-AA44-C5-ND,R2E220-AA44-C5-ND
R2E133-BH94-22-ND
1053-1696-ND
R2E220-AA44-97-ND
1570-1199-ND
2266-R2E190-RA26-46-ND,R2E190-RA26-46-ND
R2E175-AO79-14-ND
2266-R2E146-AW07-05-ND,R2E146-AW07-05-ND
1570-1200-ND
R2E220-AA52-46-ND
R2E150-AN89-11-ND
2266-R2E108-AA01-05-ND,R2E108-AA01-05-ND
2266-R2E225-AX52-16-ND,R2E225-AX52-16-ND
381-R4E310-AO32-17-ND
R2E120-CD70-09-ND
R2D220-AA24-13-ND
2266-R4E280-AA01-25-ND,R4E280-AA01-25-ND
R2E250-AU51-05-ND
R2E225-AX52-20-ND
2266-R3G220-RD49-04-ND,381-2790-ND
R3G175-AF19-02-ND
R4E310-AQ19-10-ND
R2E250-AS47-26-ND
R3G250-RE09-07-ND
R3G220-RD21-03-ND
603-1830-ND
R6E400-AE11-09-ND
603-1831-ND
R2E180-AU01-10-ND
603-1875-ND
R4E355-AK05-06-ND
R4E400-AP17-11-ND
603-1877-ND
603-1876-ND
603-1878-ND
603-1881-ND
603-1883-ND
603-1884-ND
603-1882-ND
603-1879-ND
603-1885-ND
603-1887-ND
603-1880-ND
603-1886-ND
603-1888-ND
R3G310-AI01-81-ND
R2E133-BB66-13-ND
R2E190-AE26-29-ND
R2E190-AE50-29-ND
R2S133-AB25-22-ND
R4E225-AC15-18-ND
R4E225-AR01-05-ND
R4E225-AR15-09-ND
381-3124-ND
2266-R4E355-AF13-09-ND,R4E355-AF13-09-ND
R4S175-AA16-12-ND
R4S190-AA16-18-ND
R4S225-AA16-12-ND
381-2552-ND
RH31M-4/104369-ND
RH31M-4/104370-ND
RH31M-4/104371-ND
RH31M-4/204988-ND
RH31M-6/104372-ND
RH31M-6/104373-ND
RH31M-6/204984-ND
RH35M-4/108499-ND
RH35M-4/203494-ND
RH35M-6/202667-ND
RH35M-6/204698-ND
RH40M-4/105553-ND
RH40M-4/203473-ND
RH40M-6/111192-ND
RH40M-6/206522-ND
RH45M-4/203472-ND
RH45M-4/206863-ND
RH45M-6/120404-ND
RH45M-6/206523-ND
381-3177-ND
381-2403-ND
2266-R4E310-AE05-17-ND,381-2404-ND
381-2711-ND
R3G500-AG25-64F-ND
R3G500-AG34-63F-ND
R3G560-AH23-65F-ND
R3G560-AH29-66F-ND
R3G630-AB21-62F-ND
R3G630-AB30-63F-ND
R3G630-AC05-61F-ND
R3G310-AX52-90-ND
R3G310-AX54-21-ND
R3G310-AY73-13-ND
R3G310-AZ88-03-ND
2266-R3G310-BB49-03-ND,R3G310-BB49-03-ND
R3G310-RB01-03-ND
R3G310-RR05-H1-ND
R3G310-RS01-I1-ND
R3G310-RS05-J1-ND
R4E310-RA06-01-ND
2266-R2E220-AB06-05-ND
2266-R4D280-CI01-07-ND
1570-1851-ND
1570-1855-ND
2266-R2D180-AL10-13-ND,R2D180-AL10-13-ND
R2D220-AB02-11-ND
R2E140-AE77-05-ND
R2E180-AH05-34-ND
R2E190-AO26-30-ND
R2E190-AO74-91-ND
381-3509-ND
2266-R2E190-RA26-45-ND,R2E190-RA26-45-ND
R2E190-RA50-16-ND
R2E190-RB88-14-ND
R2E220-AA44-05-ND
2266-R2E220-RB06-01-ND,381-3516-ND
R2E225-AB13-05-ND
2266-R2E225-AG05-20-ND,R2E225-AG05-20-ND
R2E225-AT55-12-ND
R2E225-BA47-11-ND
R2E225-BD92-58-ND
R2E225-BE47-19-ND
R2E225-RA92-10-ND
R2E250-AL27-17-ND
R2E250-RA50-11-ND
R2E250-RA50-14-ND
R2E250-RB06-01-ND
R2E250-RB06-16-ND
2266-R2S133-AE77-27-ND,R2S133-AE77-27-ND
2266-R3G220-RC11-04-ND,R3G220-RC11-04-ND
R3G250-AK41-71-ND
R3G250-AV29-B1-ND
R3G280-RR03-H1-ND
R3G355-AM29-71-ND
R3G355-AM36-81-ND
R4E280-AJ27-10-ND
R4E310-A012-14-ND
2266-R4E310-AO32-11-ND,381-3550-ND
R4E310-AO32-13-ND
R4E310-AT06-01-ND
R4E355-AF05-15-ND
381-3553-ND
R4E355-AK05-09-ND
381-R3G280-RB52-05-ND
381-R4E355-AF05-05-ND
381-R4E355-AF05-16-ND
381-R4E355-AF13-13-ND
381-R4E355-AF05-18-ND
381-R4E355-AF05-17-ND
OAB22599-11-1B
R2E220-AA44-23
RER125-19/56
RER160-28/06S
OAB400-22-1
R4E310-AQ31-12
R4E310-AE13-16
R2E225-BD92-09
RER160-28/56S
R2E180-AS77-05
R2E175-AO77-14
R2E220-AA44-98
R2E175-AC77-15
R2E220-AA40-B8
R4E225-AI01-10
R2E225-BD92-37
R4E280-AD12-15
R2D250-AF10-12
R4E400-AP17-06
UF190APA12-H1C2F
UF220APA12-H2C2A-B1
R2E220-AD19-11
R2S175-AB56-30
R2E175-AO79-12
R2E133-BH66-05
R2E180-CB28-01
OAB250-11-1
R2S133-AE17-05
R2E175-AC79-22
R2E140-AL40-05
R2E180-AS77-22
R2E190-AO84-22
OAB318-11-1
R2D220-AB02-10
R4E250-AH01-05
R2E250-AV65-01
OAB360-22-1
R4E310-AP15-11
R4E310-AQ29-11
R2E225-BE47-18
R2E225-AG01-21
R4E400-AP15-10
R4E355-AL02-06
OAB13372-22-1WB
OAB18055-11-1WB
UF175AMA23-H1C2A
UF225(99)APA12-H1C2F
UF190APA23-H1C2F
UF220APA23-H2C2F
UF225(99)APA23-H1C2F
R2E175-AO77-12
R2E250-AW50-05
UF180(55)APA12-H2C2A
UF220APA12-H2C2F
R2E150-AN89-14
R4S190-AC16-12
R2E220-AA40-23
R2E190-RA50-21
R2E225-RA40-21
R2E225-BE51-09
R2E225-BE47-09
R2E280-AE52-05
R2E250-RB02-11
R3G190-RD45-03
R4E355-AN09-10
UF190APA12-H1C2A
R2S133-AE77-22
R2E190-RA26-05
UF225(99)APA23-H1C2A
UF250APA12-H1C2A
R2E133-BH72-13
R2E220-RA38-13
R2E220-AA40-71
R2E225-RA92-09
R2E225-RA92-20
R2E175-AC77-18
R2E140-AS77-05
R2E220-AA40-05
OAB250-22-1
R2E180-AT06-15
R2E175-AC91-05
R2E250-RA50-01
R2E220-AB06-40
R4E280-AD08-13
R2E225-BD40-21
R2E225-AT51-05
R2E225-BE51-13
R2E250-AL05-16
R3G220-RD53-03
R3G225-RE19-04
R3G250-RE21-08
UF190APA23-H1C2A
UF133(91)APA12-H1S2A
UF175AMA12-H1C2A
UF220APA12-H2C2A
OAB190-11-1
OAB22599-22-1
R2S133-AE17-22
R2E190-RA26-20
UF250APA23-H1C2A
UF250APA12-H1C2F
R2E180-AT38-10
R2E180-AS77-40
R2S175-AB56-01
R2E133-BH66-07
R2S175-AA07-39
R2E175-AR70-05
R4E225-AT15-10
R2E220-AE86-13
R2S133-AE17-43
R2E140-AI31-30
R2E175-AC77-05
OAB360-11-1
R2E225-BD40-28
R2E225-AX52-05
R4E180-AB09-29
R2E225-BD92-36
UF360AAA12-H1C4A
UF360AAA23-H1C4A
R2D180-AL10-18
R4E310-AP11-12
R4E310-AO12-10
R2E225-BA47-09
UF400AAA23-H1C4A
R3G220-RC05-03
R2E250-RA50-09
R3G190-RD47-04
R2E250-AS47-09
R3G250-RE07-07
R4E355-AN09-12
R3G280-AF45-81
R3G280-AF35-71
OAB13391-22-1WB
UF133(72)APA23-H1S2A
UF180(55)APA23-H2C2A
UF180(55)APA23-H1C4A
UF220APA23-H2C2A
OAB220-22-1
R2S175-AB60-38
UF190APA12-H1C2A-B1
UF225(69)APA12-H1C2A
UF225(85)APA12-H1C2A
UF318AAA12-H1C4A-CC
UF318AAA23-H1C4A
UF318AAA23-H1C4A-L32
R4E250-AB01-25
W2D250-CH12-14
A4E350-AA06-56
R3G225-RE07-03
GTB019BUA07R-V E1
OAB13372-11-1WB
OAB13391-11-1WB
UF220APA12-H2/LC2A
UF133(72)APA12-H1S2A
OAB18055-22-1WB
R2E190-AO50-16
OAB190-22-1
OAB22569-11-1WB
OAB22569-22-1WB
OAB22585-11-1WB
OAB22585-22-1WB
OAB220-11-1
R2E190-AO26-25
UF225(85)APA12-H1C2F
UF225(99)APA12-H1C2A
R2E220-RA44-14
UF250APA12-H1C4A
R2E220-AA40-80
R2E220-AA44-C5
R2E133-BH94-22
OAB318-22-1
R2E220-AA44-97
UF250APA23-H1C2F
R2E190-RA26-46
R2E175-AO79-14
R2E146-AW07-05
UF318AAA12-H1C4A
R2E220-AA52-46
R2E150-AN89-11
R2E108-AA01-05
R2E225-AX52-16
R4E310-AO32-17
R2E120-CD70-09
R2D220-AA24-13
R4E280-AA01-25
R2E250-AU51-05
R2E225-AX52-20
R3G220-RD49-04
R3G175-AF19-02
R4E310-AQ19-10
R2E250-AS47-26
R3G250-RE09-07
R3G220-RD21-03
GTB028EUB16
R6E400-AE11-09
GTB028EUB16 N1
R2E180-AU01-10
GTB036FUC21R
R4E355-AK05-06
R4E400-AP17-11
GTB036FUC23R
GTB036FUC21R N1
GTB036FUC23R N1
GTB040FUC20R
GTB040FUC23R
GTB040FUC23R N1
GTB040FUC20R N1
GTB036PUD25R
GTB040PUD26R
GTB040PUD27R
GTB036PUD25R N1
GTB040PUD26R N1
GTB040PUD27R N1
R3G310-AI01-81
R2E133-BB66-13
R2E190-AE26-29
R2E190-AE50-29
R2S133-AB25-22
R4E225-AC15-18
R4E225-AR01-05
R4E225-AR15-09
R4E355-AF05-09
R4E355-AF13-09
R4S175-AA16-12
R4S190-AA16-18
R4S225-AA16-12
RER125-19/06
RH31M-4/104369
RH31M-4/104370
RH31M-4/104371
RH31M-4/204988
RH31M-6/104372
RH31M-6/104373
RH31M-6/204984
RH35M-4/108499
RH35M-4/203494
RH35M-6/202667
RH35M-6/204698
RH40M-4/105553
RH40M-4/203473
RH40M-6/111192
RH40M-6/206522
RH45M-4/203472
RH45M-4/206863
RH45M-6/120404
RH45M-6/206523
R2E190-AO26-05
R2E250-AS47-05
R4E310-AE05-17
R2E250-RB06-12
R3G500-AG25-64F
R3G500-AG34-63F
R3G560-AH23-65F
R3G560-AH29-66F
R3G630-AB21-62F
R3G630-AB30-63F
R3G630-AC05-61F
R3G310-AX52-90
R3G310-AX54-21
R3G310-AY73-13
R3G310-AZ88-03
R3G310-BB49-03
R3G310-RB01-03
R3G310-RR05-H1
R3G310-RS01-I1
R3G310-RS05-J1
R4E310-RA06-01
R2E220-AB06-05
R4D280-CI01-07
UF190APA23H12CA
UF220APA23-H1C2A
R2D180-AL10-13
R2D220-AB02-11
R2E140-AE77-05
R2E180-AH05-34
R2E190-AO26-30
R2E190-AO74-91
R2E190-AP88-14
R2E190-RA26-45
R2E190-RA50-16
R2E190-RB88-14
R2E220-AA44-05
R2E220-RB06-01
R2E225-AB13-05
R2E225-AG05-20
R2E225-AT55-12
R2E225-BA47-11
R2E225-BD92-58
R2E225-BE47-19
R2E225-RA92-10
R2E250-AL27-17
R2E250-RA50-11
R2E250-RA50-14
R2E250-RB06-01
R2E250-RB06-16
R2S133-AE77-27
R3G220-RC11-04
R3G250-AK41-71
R3G250-AV29-B1
R3G280-RR03-H1
R3G355-AM29-71
R3G355-AM36-81
R4E280-AJ27-10
R4E310-A012-14
R4E310-AO32-11
R4E310-AO32-13
R4E310-AT06-01
R4E355-AF05-15
R4E355-AG04-13
R4E355-AK05-09
R3G280-RB52-05
R4E355-AF05-05
R4E355-AF05-16
R4E355-AF13-13
R4E355-AF05-18
R4E355-AF05-17
