Hi - I am looking to identify this capacitor or find an equivalent. I measured the capacitance and it was reading 18 uF.
I am not sure on the voltage rating for that item.
I found the below based on the 226 marked on that item for capacitance.
22 µF Through Hole Ceramic Capacitors | Electronic Components Distributor DigiKey
Thanks Nathan - it came from a system that was using a +/- 15V DC power supply. Should I match the voltage rating to the power supply, 16V rating in this case or should I go larger to be safe?
Hi pbrister
You can use a 16V or higher. Using a higher voltage rated capacitor should not damage or effect the circuit.
Perfect - thank you Becky!
