number on ceramic capacitor is , YF 473 DC 150v , need replacement, its on a bridge rectifier in a old amp thanks
Hello sekib40,
Welcome to the DigiKey TechForum! We do have quite a number of 47nF ceramic capacitors that can handle the 150v which you will find below:
If you know the mounting type and size of the capacitor, that will help narrow down the results.
Regards,
Klint
I need ceramic capacitor, 47000pf nf47 uf 0.047 but I don’t know if 150 volt dc is available what else can i use 200 volt dc or 300 volt ac ,am I making any sense lol
Hello Agin,
You can use any volts higher the the 150Volts.
The voltage rating just means the max the capacitor can handle before blowing up.
Here is a list of some options
