Hi there,
With regards to the below cable
CAT6-3041D-FTP-B Ease Electronics | Multiple Conductor Cables | DigiKey
Can you please provide:
- Compatible RJ45 connector part number and datasheet (standard crimp or pass-through connectors are both acceptable).
- Confirmation that the cable and connector combination supports IEEE 802.3bt Type 4 (PoE++).
- Any DSX test reports at elevated temperature (for example 70°C), if available.
- Confirm that the cable complies with AS/CA S008 and the applicable AS/NZS 11801 requirements.
Thanks
