Request for equivalent
Hi Tech team,
I need your technical team to check whether you have any similar with finished goods below. If any, please provide the MPN to verify. I need in black, red and blue jacket colour.
If do not have, please help to check whether have similar item below?
  1. CONN: CAT 8.1, RJ45, 8P8C, SHIELDED, GOLD PLATED
  2. SR HOOD: RJ45, FOR CABLE OD: 7.8mm
    I need in black, red and blue.
Hello Erik09 - We have this Cat 8.1 cable assembly 380-CA88-020M-01-ND, which is in stock. The cable is gray and is 2 meters in length. We have this non-stocking option, also 2 meters and gray in color. This cable is not in stock, but it is orderable. DigiKey part number is 380-CA81-020M-01-ND.
Following are links to connectors and covers: RJ45 plugs RJ45 Covers
