I need a part number for CAT5 patch cable with ethernet ends on both ends in 12 inch or less length also 1 need the same in a 3 foot length. Thank you
For 12" or less here are some options we have in stock. You would need to sort still based on Shielding, and color. Modular/Ethernet Cables (RJ45, RJ11) | Electronic Components Distributor DigiKey
Here is a similar list at 3 feet. Again there will be some sorting. Modular/Ethernet Cables (RJ45, RJ11) | Electronic Components Distributor DigiKey
If you need help narrowing down options let me know.
-Robert
