Ceramic capacitor replacement with a DigiKey product?
I have a board to fix which you can see has an exploded capacitor. In case it is hard to see, the markings say:
“R.
221K
1 kV”
which I believe to be 220pF @ 10% tolerance, supporting 1kV. I have no clue what the “R.” means, perhaps someone knows?
Could someone help me confirm whether this part is a good replacement ? https://www.digikey.ch/en/products/detail/tdk-corporation/CK45-B3AD221KYVNA/7383709
Thanks in advance,
Kenneth
Hello Kennethfm
Regarding capacitor marking 221K 1KV this will be for 220pF 1KV 10%.
Please consider 445-175509-ND
Best regards,
Hello Troy_2808,
Thank you for your advice. Do you know if the “R.” means temperature coefficient ? If yes, would 445-175509-ND be suitable given that it’s temperature coefficient is “B” ?
Thank you again,
Kenneth
The “R” tempco (+15, –30%) has been made obsolete. The “B” type (+10, -10%) is an excellent replacement choice.
Great. Thanks, Paul!
