Please clarify if the Molex connector 0334822423 can be mounted on the side wall of a panel, Do I need any accessories like mounting bracket separately.
Currently I have considered 0334822423 - 1no & 330111006 - 20no. Is this enough or I need to take any other accessories.
Welcome to the DigiKey TechForum. Part 0334822423 is an inline (cable to cable) mounting connector so there are no mounting brackets available, you will need to create a mounting system that will work for your application. The pins you have selected will work but are currently out of stock, take a look at these pin options that we currently have available.
