When working with CIT Relay & Switch products, it is crucial to follow proper soldering and cleaning guidelines to maintain product integrity.
While the terminal areas are epoxy-sealed to prevent flux wicking into the relay cavity, the covers, actuators, and bushings are not sealed. This means that exposing the switch to cleaning fluids, whether by immersion or spraying, could lead to contamination and potential damage.
Additionally, during soldering, flux vapors can settle on internal components, so good ventilation is recommended. If a cleaning process is required, care should be taken to ensure that the switches are not immersed or sprayed with any fluids or solutions.
Check this for more details:
CIT SWITCH Soldering Recommendations.pdf (98.5 KB)
Applicable Part Numbers
DigiKey Part Number | Manufacturer Part Number |
2449-MS1206L6-ND | MS1206L6 |
2449-MS1201L2B-ND | MS1201L2B |
2449-MS1201L2A-ND | MS1201L2A |
2449-MS1201L5A-ND | MS1201L5A |
2449-MS1201L4B-ND | MS1201L4B |
2449-MS1247L6-ND | MS1247L6 |
2449-MS1201L4A-ND | MS1201L4A |
2449-MS1201L5B-ND | MS1201L5B |
2449-MS1202L4-ND | MS1202L4 |
2449-MS1202L6-ND | MS1202L6 |
2449-MS12711-ND | MS12711 |
2449-MS2241L6-ND | MS2241L6 |
2449-MS2241L9-ND | MS2241L9 |
2449-MS4208L4-ND | MS4208L4 |
2449-1101A2CQEA-ND | 1101A2CQEA |
2449-1101A1VQEA-ND | 1101A1VQEA |
2449-MS1206L3-ND | MS1206L3 |
2449-MS1247L4-ND | MS1247L4 |
2449-MS1247L2-ND | MS1247L2 |
2449-MS2219L4-ND | MS2219L4 |
2449-MS12712-ND | MS12712 |
2449-MS2201L3-ND | MS2201L3 |
2449-MS2201L4.5-ND | MS2201L4.5 |
2449-MS2201L12-ND | MS2201L12 |
2449-MS2201L9-ND | MS2201L9 |
2449-MS2201L6-ND | MS2201L6 |
2449-MS2310L6-ND | MS2310L6 |
2449-MS2310L4-ND | MS2310L4 |
2449-MS2205L6-ND | MS2205L6 |
2449-MS2208L4-ND | MS2208L4 |
2449-MS2205L2-ND | MS2205L2 |
2449-MS2205L4-ND | MS2205L4 |
2449-MS2305L2-ND | MS2305L2 |
2449-MS2305L4-ND | MS2305L4 |
2449-MS2211L4-ND | MS2211L4 |
2449-MS2241L3-ND | MS2241L3 |
2449-MS2210L6-ND | MS2210L6 |
2449-MS2210L4-ND | MS2210L4 |
2449-MS2301L6-ND | MS2301L6 |
2449-MS2301L12-ND | MS2301L12 |
2449-MS2301L3-ND | MS2301L3 |
2449-MS2301L9-ND | MS2301L9 |
2449-MS2301L4.5-ND | MS2301L4.5 |
2449-MS2309L4-ND | MS2309L4 |
2449-MS2309L6-ND | MS2309L6 |
2449-MS2202L8B-ND | MS2202L8B |
2449-MS2202L8A-ND | MS2202L8A |
2449-MS2202L5B-ND | MS2202L5B |
2449-MS2202L9A-ND | MS2202L9A |
2449-MS2202L9B-ND | MS2202L9B |
2449-MS2202L5A-ND | MS2202L5A |
2449-1101A2HREA-ND | 1101A2HREA |
2449-1101A4CQEA-ND | 1101A4CQEA |
2449-1101A2HQEA-ND | 1101A2HQEA |
2449-1101A3BQEB-ND | 1101A3BQEB |
2449-1103A4BQEB-ND | 1103A4BQEB |
2449-1103A1VQEA-ND | 1103A1VQEA |
2449-1103A3BQEB-ND | 1103A3BQEB |
2449-1201A3BQEB-ND | 1201A3BQEB |
2449-1101A3VREA-ND | 1101A3VREA |
2449-1201A1VREA-ND | 1201A1VREA |
2449-1203A1CQEA-ND | 1203A1CQEA |
2449-1101A4BREB-ND | 1101A4BREB |
2449-1101A2BQEB-ND | 1101A2BQEB |
2449-1101A1BQEB-ND | 1101A1BQEB |
2449-1101A4BQEB-ND | 1101A4BQEB |
2449-1101A2VQEA-ND | 1101A2VQEA |
2449-1103A2CQEA-ND | 1103A2CQEA |
2449-1103A1BQEB-ND | 1103A1BQEB |
2449-1101A1BREB-ND | 1101A1BREB |
2449-1201A2BQEB-ND | 1201A2BQEB |
2449-1201A1BQEB-ND | 1201A1BQEB |
2449-1203A1BREB-ND | 1203A1BREB |
2449-1101A2VREA-ND | 1101A2VREA |
2449-1101A1VREA-ND | 1101A1VREA |
2449-1201A4BQEB-ND | 1201A4BQEB |
2449-1103A1BREB-ND | 1103A1BREB |
2449-1201A1VQEA-ND | 1201A1VQEA |
2449-1203A2BQEB-ND | 1203A2BQEB |
2449-1203A2CQEA-ND | 1203A2CQEA |
2449-1203A1BQEB-ND | 1203A1BQEB |
2449-1201A1BREB-ND | 1201A1BREB |
2449-1203A4BQEB-ND | 1203A4BQEB |
2449-1203A4CQEA-ND | 1203A4CQEA |
2449-1203A1VQEA-ND | 1203A1VQEA |
2449-1203A3BQEB-ND | 1203A3BQEB |
2449-1201A2CQEA-ND | 1201A2CQEA |
2449-1103A2BQEB-ND | 1103A2BQEB |
2449-1103A4CQEA-ND | 1103A4CQEA |
2449-1201A4CQEA-ND | 1201A4CQEA |
2449-1102A1CQEA-ND | 1102A1CQEA |
2449-1102A2BQEB-ND | 1102A2BQEB |
2449-1102A1BQEB-ND | 1102A1BQEB |
2449-1102A2CQEA-ND | 1102A2CQEA |
2449-1101A1CQEA-ND | 1101A1CQEA |
2449-1101A1BQEA-ND | 1101A1BQEA |
2449-1102A4BQEB-ND | 1102A4BQEB |
2449-1102A4CQEA-ND | 1102A4CQEA |
2449-1101A2DQEB-ND | 1101A2DQEB |
2449-1101A1DQEB-ND | 1101A1DQEB |
2449-1102A1DQEB-ND | 1102A1DQEB |
2449-1102A2DQEB-ND | 1102A2DQEB |
2449-1101A1HQEA-ND | 1101A1HQEA |
2449-1102A2VQEA-ND | 1102A2VQEA |
2449-1102A1HQEA-ND | 1102A1HQEA |
2449-1102A2HQEA-ND | 1102A2HQEA |
2449-1102A1VQEA-ND | 1102A1VQEA |
2449-1101A3CQEA-ND | 1101A3CQEA |
2449-1101A3BQEA-ND | 1101A3BQEA |
2449-1102A3CQEA-ND | 1102A3CQEA |
2449-1102A3BQEB-ND | 1102A3BQEB |
2449-1102A4DQEB-ND | 1102A4DQEB |
2449-1101A4DQEB-ND | 1101A4DQEB |
2449-1103A1BQEA-ND | 1103A1BQEA |
2449-1103A1CQEA-ND | 1103A1CQEA |
2449-1101A1BREA-ND | 1101A1BREA |
2449-1101A1CREA-ND | 1101A1CREA |
2449-1101A2CREA-ND | 1101A2CREA |
2449-1102A2BREB-ND | 1102A2BREB |
2449-1102A2CREA-ND | 1102A2CREA |
2449-1101A2BREB-ND | 1101A2BREB |
2449-1102A1CREA-ND | 1102A1CREA |
2449-1102A1BREB-ND | 1102A1BREB |
2449-1102A4HQEA-ND | 1102A4HQEA |
2449-1101A4VQEA-ND | 1101A4VQEA |
2449-1101A4HQEA-ND | 1101A4HQEA |
2449-1102A4VQEA-ND | 1102A4VQEA |
2449-1101A3CREA-ND | 1101A3CREA |
2449-1102A3DQEB-ND | 1102A3DQEB |
2449-1101A3DQEB-ND | 1101A3DQEB |
2449-1103A1DQEB-ND | 1103A1DQEB |
2449-1103A2DQEB-ND | 1103A2DQEB |
2449-1201A1BQEA-ND | 1201A1BQEA |
2449-1101A3HQEA-ND | 1101A3HQEA |
2449-1201A1CQEA-ND | 1201A1CQEA |
2449-1102A4CREA-ND | 1102A4CREA |
2449-1102A4BREB-ND | 1102A4BREB |
2449-1101A4CREA-ND | 1101A4CREA |
2449-1102A3VQEA-ND | 1102A3VQEA |
2449-1101A3VQEA-ND | 1101A3VQEA |
2449-1102A3HQEA-ND | 1102A3HQEA |
2449-1102A2DREB-ND | 1102A2DREB |
2449-1102A1DREB-ND | 1102A1DREB |
2449-1101A2DREB-ND | 1101A2DREB |
2449-1101A1DREB-ND | 1101A1DREB |
2449-1103A1HQEA-ND | 1103A1HQEA |
2449-1103A2VQEA-ND | 1103A2VQEA |
2449-1103A2HQEA-ND | 1103A2HQEA |
2449-1103A3CQEA-ND | 1103A3CQEA |
2449-1103A3BQEA-ND | 1103A3BQEA |
2449-1102A1HREA-ND | 1102A1HREA |
2449-1102A1VREA-ND | 1102A1VREA |
2449-1102A2HREA-ND | 1102A2HREA |
2449-1102A2VREA-ND | 1102A2VREA |
2449-1101A1HREA-ND | 1101A1HREA |
2449-1103A4DQEB-ND | 1103A4DQEB |
2449-1101A3BREB-ND | 1101A3BREB |
2449-1102A3CREA-ND | 1102A3CREA |
2449-1102A3BREB-ND | 1102A3BREB |
2449-1101A3BREA-ND | 1101A3BREA |
2449-1201A1DQEB-ND | 1201A1DQEB |
2449-1201A2DQEB-ND | 1201A2DQEB |
2449-1103A2CREA-ND | 1103A2CREA |
2449-1101A4DREB-ND | 1101A4DREB |
2449-1103A2BREB-ND | 1103A2BREB |
2449-1102A4DREB-ND | 1102A4DREB |
2449-1103A4VQEA-ND | 1103A4VQEA |
2449-1103A4HQEA-ND | 1103A4HQEA |
2449-1103A1BREA-ND | 1103A1BREA |
2449-1103A1CREA-ND | 1103A1CREA |
2449-1201A1HQEA-ND | 1201A1HQEA |
2449-1201A2HQEA-ND | 1201A2HQEA |
2449-1101A4HREA-ND | 1101A4HREA |
2449-1102A4VREA-ND | 1102A4VREA |
2449-1201A2VQEA-ND | 1201A2VQEA |
2449-1102A4HREA-ND | 1102A4HREA |
2449-1101A4VREA-ND | 1101A4VREA |
2449-1103A3DQEB-ND | 1103A3DQEB |
2449-1201A3BQEA-ND | 1201A3BQEA |
2449-1201A3CQEA-ND | 1201A3CQEA |
2449-1203A1BQEA-ND | 1203A1BQEA |
2449-1103A4CREA-ND | 1103A4CREA |
2449-1101A3DREB-ND | 1101A3DREB |
2449-1201A4DQEB-ND | 1201A4DQEB |
2449-1102A3DREB-ND | 1102A3DREB |
2449-1103A4BREB-ND | 1103A4BREB |
2449-1203A3BQEA-ND | 1203A3BQEA |
2449-1103A3VQEA-ND | 1103A3VQEA |
2449-1103A3HQEA-ND | 1103A3HQEA |
2449-1103A2DREB-ND | 1103A2DREB |
2449-1103A1DREB-ND | 1103A1DREB |
2449-1101A3HREA-ND | 1101A3HREA |
2449-1201A4VQEA-ND | 1201A4VQEA |
2449-1102A3HREA-ND | 1102A3HREA |
2449-1102A3VREA-ND | 1102A3VREA |
2449-1201A4HQEA-ND | 1201A4HQEA |
2449-1103A2VREA-ND | 1103A2VREA |
2449-1103A2HREA-ND | 1103A2HREA |
2449-1103A1VREA-ND | 1103A1VREA |
2449-1201A1BREA-ND | 1201A1BREA |
2449-1201A1CREA-ND | 1201A1CREA |
2449-1103A1HREA-ND | 1103A1HREA |
2449-1201A2BREB-ND | 1201A2BREB |
2449-1201A2CREA-ND | 1201A2CREA |
2449-1103A3BREB-ND | 1103A3BREB |
2449-1201A3DQEB-ND | 1201A3DQEB |
2449-1103A3CREA-ND | 1103A3CREA |
2449-1103A3BREA-ND | 1103A3BREA |
2449-1103A4DREB-ND | 1103A4DREB |
2449-1203A2DQEB-ND | 1203A2DQEB |
2449-1203A1DQEB-ND | 1203A1DQEB |
2449-1201A3VQEA-ND | 1201A3VQEA |
2449-1201A3HQEA-ND | 1201A3HQEA |
2449-1203A1HQEA-ND | 1203A1HQEA |
2449-1103A4HREA-ND | 1103A4HREA |
2449-1103A4VREA-ND | 1103A4VREA |
2449-1203A2HQEA-ND | 1203A2HQEA |
2449-1203A2VQEA-ND | 1203A2VQEA |
2449-1201A4BREB-ND | 1201A4BREB |
2449-1201A4CREA-ND | 1201A4CREA |
2449-1201A1DREB-ND | 1201A1DREB |
2449-1201A2DREB-ND | 1201A2DREB |
2449-1203A3CQEA-ND | 1203A3CQEA |
2449-1103A3DREB-ND | 1103A3DREB |
2449-1203A4DQEB-ND | 1203A4DQEB |
2449-1201A2VREA-ND | 1201A2VREA |
2449-1201A2HREA-ND | 1201A2HREA |
2449-1201A1HREA-ND | 1201A1HREA |
2449-1103A3HREA-ND | 1103A3HREA |
2449-1103A3VREA-ND | 1103A3VREA |
2449-1203A4VQEA-ND | 1203A4VQEA |
2449-1203A4HQEA-ND | 1203A4HQEA |
2449-1201A3BREB-ND | 1201A3BREB |
2449-1201A3CREA-ND | 1201A3CREA |
2449-1201A3BREA-ND | 1201A3BREA |
2449-1203A1CREA-ND | 1203A1CREA |
2449-1203A1BREA-ND | 1203A1BREA |
2449-1201A4DREB-ND | 1201A4DREB |
2449-1203A2CREA-ND | 1203A2CREA |
2449-1203A2BREB-ND | 1203A2BREB |
2449-1203A3DQEB-ND | 1203A3DQEB |
2449-1201A4VREA-ND | 1201A4VREA |
2449-1201A4HREA-ND | 1201A4HREA |
2449-1203A3VQEA-ND | 1203A3VQEA |
2449-1203A3HQEA-ND | 1203A3HQEA |
2449-1203A4BREB-ND | 1203A4BREB |
2449-1201A3DREB-ND | 1201A3DREB |
2449-1203A4CREA-ND | 1203A4CREA |
2449-1203A2DREB-ND | 1203A2DREB |
2449-1203A1DREB-ND | 1203A1DREB |
2449-1201A3VREA-ND | 1201A3VREA |
2449-1201A3HREA-ND | 1201A3HREA |
2449-1203A1VREA-ND | 1203A1VREA |
2449-1203A2HREA-ND | 1203A2HREA |
2449-1203A2VREA-ND | 1203A2VREA |
2449-1203A1HREA-ND | 1203A1HREA |
2449-1203A3BREB-ND | 1203A3BREB |
2449-1203A3BREA-ND | 1203A3BREA |
2449-1203A3CREA-ND | 1203A3CREA |
2449-1203A4DREB-ND | 1203A4DREB |
2449-1203A4HREA-ND | 1203A4HREA |
2449-1203A4VREA-ND | 1203A4VREA |
2449-1203A3DREB-ND | 1203A3DREB |
2449-1203A3HREA-ND | 1203A3HREA |
2449-1203A3VREA-ND | 1203A3VREA |
