CMICR-PWR-CNT=, connecten
What connecten can i use for this?
Part: CMICR-PWR-CNT=.
Is this correct?
Hello Mikael,
Thank you for your post.
I believe the type of part you are looking for would be closer to our part 277-6341-ND.
The tough part is knowing the pin spacing and also the wire gauge that it is using.
The other difficult part with the item in the first picture is with the backshell on it, I’m not sure if it has something like screw terminals for retaining the wire.
Hi, thansk for the answer. But this cant be correct, becuse is shude be “Female Connector,3 Poles”
You have given me a male typ.
This connector is for a “Cisco Catalyst Micro Switches”. So the backshell is for Cisco Catalyst Micro Switches. Something should be connected to “CMICR-PWR-CNT”. So use the picture 2 for reference.
I need somthing for the “3-pin Industiral Plug”
mikael.hellqvist
Below is a link for they type of connectors that may mate to that cable assembly , as Brent stated you will need to know the pitch first to see if we have the correct mate .
Headers, Plugs and Sockets | Terminal Blocks | Electronic Components Distributor DigiKey
Thanks Craig
Hi mikael.hellqvist,
To narrow down your options, you need to measure the pitch “P”, as seen in the diagram below.
Then select parts with that pitch from these options.
Thanks, i found this 3
Will check more carefully and see which one fits best.
Thanks for the help
