The 3239 series wire from CNC Tech has 2 sections within the part number that are used to determine both the wire size and color
The first set of X’s in the part number are for the wire gauge and the second set of X’s is for the color. The wire gauges that are offered in the 3239 series at DigiKey range from 10 AWG to 24 AWG. The colors that the 3239 series come in are Black, White, Yellow, Red, Blue, Brown, Green, Orange, and Green/Yellow. To select your color, you would enter the corresponding number for the color you want from the chart below.
Applicable Part Numbers
| DK Part # | Mfr Part # |
| 1175-3239-10-1-0100-001-1-TS-ND | 3239-10-1-0100-001-1-TS |
| 1175-3239-10-1-0100-002-1-TS-ND | 3239-10-1-0100-002-1-TS |
| 1175-3239-10-1-0100-003-1-TS-ND | 3239-10-1-0100-003-1-TS |
| 1175-3239-10-1-0100-004-1-TS-ND | 3239-10-1-0100-004-1-TS |
| 1175-3239-10-1-0100-005-1-TS-ND | 3239-10-1-0100-005-1-TS |
| 1175-3239-10-1-0100-006-1-TS-ND | 3239-10-1-0100-006-1-TS |
| 1175-3239-10-1-0100-007-1-TS-ND | 3239-10-1-0100-007-1-TS |
| 1175-3239-10-1-0100-011-1-TS-ND | 3239-10-1-0100-011-1-TS |
| 1175-3239-12-1-0100-001-1-TS-ND | 3239-12-1-0100-001-1-TS |
| 1175-3239-12-1-0100-002-1-TS-ND | 3239-12-1-0100-002-1-TS |
| 1175-3239-12-1-0100-003-1-TS-ND | 3239-12-1-0100-003-1-TS |
| 1175-3239-12-1-0100-004-1-TS-ND | 3239-12-1-0100-004-1-TS |
| 1175-3239-12-1-0100-005-1-TS-ND | 3239-12-1-0100-005-1-TS |
| 1175-3239-12-1-0100-006-1-TS-ND | 3239-12-1-0100-006-1-TS |
| 1175-3239-12-1-0100-007-1-TS-ND | 3239-12-1-0100-007-1-TS |
| 1175-3239-12-1-0100-011-1-TS-ND | 3239-12-1-0100-011-1-TS |
| 1175-3239-14-1-0100-001-1-TS-ND | 3239-14-1-0100-001-1-TS |
| 1175-3239-14-1-0100-002-1-TS-ND | 3239-14-1-0100-002-1-TS |
| 1175-3239-14-1-0100-003-1-TS-ND | 3239-14-1-0100-003-1-TS |
| 1175-3239-14-1-0100-004-1-TS-ND | 3239-14-1-0100-004-1-TS |
| 1175-3239-14-1-0100-005-1-TS-ND | 3239-14-1-0100-005-1-TS |
| 1175-3239-14-1-0100-006-1-TS-ND | 3239-14-1-0100-006-1-TS |
| 1175-3239-14-1-0100-007-1-TS-ND | 3239-14-1-0100-007-1-TS |
| 1175-3239-14-1-0100-011-1-TS-ND | 3239-14-1-0100-011-1-TS |
| 1175-3239-16-1-0500-011-1-TS-DS-ND | 3239-16-1-0500-011-1-TS |
| 1175-3239-24-1-0500-011-1-TS-DS-ND | 3239-24-1-0500-011-1-TS |
| CN104A-100-ND | 3239-22-1-0500-008-1-TS |
| CN104A-250-ND | 3239-22-1-0500-008-1-TS |
| CN104A-25-ND | 3239-22-1-0500-008-1-TS |
| CN104A-500-ND | 3239-22-1-0500-008-1-TS |
| CN104A-50-ND | 3239-22-1-0500-008-1-TS |
| CN104B-100-ND | 3239-22-1-0500-001-1-TS |
| CN104B-250-ND | 3239-22-1-0500-001-1-TS |
| CN104B-25-ND | 3239-22-1-0500-001-1-TS |
| CN104B-500-ND | 3239-22-1-0500-001-1-TS |
| CN104B-50-ND | 3239-22-1-0500-001-1-TS |
| CN104G-100-ND | 3239-22-1-0500-007-1-TS |
| CN104G-250-ND | 3239-22-1-0500-007-1-TS |
| CN104G-25-ND | 3239-22-1-0500-007-1-TS |
| CN104G-500-ND | 3239-22-1-0500-007-1-TS |
| CN104G-50-ND | 3239-22-1-0500-007-1-TS |
| CN104GY-500-ND | 3239-22-1-0500-011-1-TS |
| CN104GY-DS-ND | 3239-22-1-0500-011-1-TS |
| CN104L-100-ND | 3239-22-1-0500-005-1-TS |
| CN104L-250-ND | 3239-22-1-0500-005-1-TS |
| CN104L-25-ND | 3239-22-1-0500-005-1-TS |
| CN104L-500-ND | 3239-22-1-0500-005-1-TS |
| CN104L-50-ND | 3239-22-1-0500-005-1-TS |
| CN104N-500-ND | 3239-22-1-0500-006-1-TS |
| CN104R-100-ND | 3239-22-1-0500-004-1-TS |
| CN104R-250-ND | 3239-22-1-0500-004-1-TS |
| CN104R-25-ND | 3239-22-1-0500-004-1-TS |
| CN104R-500-ND | 3239-22-1-0500-004-1-TS |
| CN104R-50-ND | 3239-22-1-0500-004-1-TS |
| CN104V-500-ND | 3239-22-1-0500-010-1-TS |
| CN104W-100-ND | 3239-22-1-0500-002-1-TS |
| CN104W-250-ND | 3239-22-1-0500-002-1-TS |
| CN104W-25-ND | 3239-22-1-0500-002-1-TS |
| CN104W-500-ND | 3239-22-1-0500-002-1-TS |
| CN104W-50-ND | 3239-22-1-0500-002-1-TS |
| CN104Y-100-ND | 3239-22-1-0500-003-1-TS |
| CN104Y-250-ND | 3239-22-1-0500-003-1-TS |
| CN104Y-25-ND | 3239-22-1-0500-003-1-TS |
| CN104Y-500-ND | 3239-22-1-0500-003-1-TS |
| CN104Y-50-ND | 3239-22-1-0500-003-1-TS |
| CN105A-100-ND | 3239-18-1-0500-008-1-TS |
| CN105A-250-ND | 3239-18-1-0500-008-1-TS |
| CN105A-25-ND | 3239-18-1-0500-008-1-TS |
| CN105A-500-ND | 3239-18-1-0500-008-1-TS |
| CN105A-50-ND | 3239-18-1-0500-008-1-TS |
| CN105B-100-ND | 3239-18-1-0500-001-1-TS |
| CN105B-250-ND | 3239-18-1-0500-001-1-TS |
| CN105B-25-ND | 3239-18-1-0500-001-1-TS |
| CN105B-500-ND | 3239-18-1-0500-001-1-TS |
| CN105B-50-ND | 3239-18-1-0500-001-1-TS |
| CN105G-100-ND | 3239-18-1-0500-007-1-TS |
| CN105G-250-ND | 3239-18-1-0500-007-1-TS |
| CN105G-25-ND | 3239-18-1-0500-007-1-TS |
| CN105G-500-ND | 3239-18-1-0500-007-1-TS |
| CN105G-50-ND | 3239-18-1-0500-007-1-TS |
| CN105GY-500-ND | 3239-18-1-0500-011-1-TS |
| CN105GY-DS-ND | 3239-18-1-0500-011-1-TS |
| CN105L-100-ND | 3239-18-1-0500-005-1-TS |
| CN105L-250-ND | 3239-18-1-0500-005-1-TS |
| CN105L-25-ND | 3239-18-1-0500-005-1-TS |
| CN105L-500-ND | 3239-18-1-0500-005-1-TS |
| CN105L-50-ND | 3239-18-1-0500-005-1-TS |
| CN105N-500-ND | 3239-18-1-0500-006-1-TS |
| CN105R-100-ND | 3239-18-1-0500-004-1-TS |
| CN105R-250-ND | 3239-18-1-0500-004-1-TS |
| CN105R-25-ND | 3239-18-1-0500-004-1-TS |
| CN105R-500-ND | 3239-18-1-0500-004-1-TS |
| CN105R-50-ND | 3239-18-1-0500-004-1-TS |
| CN105V-500-ND | 3239-18-1-0500-010-1-TS |
| CN105W-100-ND | 3239-18-1-0500-002-1-TS |
| CN105W-250-ND | 3239-18-1-0500-002-1-TS |
| CN105W-25-ND | 3239-18-1-0500-002-1-TS |
| CN105W-500-ND | 3239-18-1-0500-002-1-TS |
| CN105W-50-ND | 3239-18-1-0500-002-1-TS |
| CN105Y-100-ND | 3239-18-1-0500-003-1-TS |
| CN105Y-250-ND | 3239-18-1-0500-003-1-TS |
| CN105Y-25-ND | 3239-18-1-0500-003-1-TS |
| CN105Y-500-ND | 3239-18-1-0500-003-1-TS |
| CN105Y-50-ND | 3239-18-1-0500-003-1-TS |
| CN118B-100-ND | 3239-20-1-0500-001-1-TS |
| CN118B-250-ND | 3239-20-1-0500-001-1-TS |
| CN118B-25-ND | 3239-20-1-0500-001-1-TS |
| CN118B-500-ND | 3239-20-1-0500-001-1-TS |
| CN118B-50-ND | 3239-20-1-0500-001-1-TS |
| CN118G-100-ND | 3239-20-1-0500-007-1-TS |
| CN118G-250-ND | 3239-20-1-0500-007-1-TS |
| CN118G-25-ND | 3239-20-1-0500-007-1-TS |
| CN118G-500-ND | 3239-20-1-0500-007-1-TS |
| CN118G-50-ND | 3239-20-1-0500-007-1-TS |
| CN118GY-500-ND | 3239-20-1-0500-011-1-TS |
| CN118GY-DS-ND | 3239-20-1-0500-011-1-TS |
| CN118L-100-ND | 3239-20-1-0500-005-1-TS |
| CN118L-250-ND | 3239-20-1-0500-005-1-TS |
| CN118L-25-ND | 3239-20-1-0500-005-1-TS |
| CN118L-500-ND | 3239-20-1-0500-005-1-TS |
| CN118L-50-ND | 3239-20-1-0500-005-1-TS |
| CN118R-100-ND | 3239-20-1-0500-004-1-TS |
| CN118R-250-ND | 3239-20-1-0500-004-1-TS |
| CN118R-25-ND | 3239-20-1-0500-004-1-TS |
| CN118R-500-ND | 3239-20-1-0500-004-1-TS |
| CN118R-50-ND | 3239-20-1-0500-004-1-TS |
| CN118W-100-ND | 3239-20-1-0500-002-1-TS |
| CN118W-250-ND | 3239-20-1-0500-002-1-TS |
| CN118W-25-ND | 3239-20-1-0500-002-1-TS |
| CN118W-500-ND | 3239-20-1-0500-002-1-TS |
| CN118W-50-ND | 3239-20-1-0500-002-1-TS |
| CN118Y-100-ND | 3239-20-1-0500-003-1-TS |
| CN118Y-250-ND | 3239-20-1-0500-003-1-TS |
| CN118Y-25-ND | 3239-20-1-0500-003-1-TS |
| CN118Y-500-ND | 3239-20-1-0500-003-1-TS |
| CN118Y-50-ND | 3239-20-1-0500-003-1-TS |
| CN120B-100-ND | 3239-24-1-0500-001-1-TS |
| CN120B-250-ND | 3239-24-1-0500-001-1-TS |
| CN120B-25-ND | 3239-24-1-0500-001-1-TS |
| CN120B-500-ND | 3239-24-1-0500-001-1-TS |
| CN120B-50-ND | 3239-24-1-0500-001-1-TS |
| CN120G-100-ND | 3239-24-1-0500-007-1-TS |
| CN120G-250-ND | 3239-24-1-0500-007-1-TS |
| CN120G-25-ND | 3239-24-1-0500-007-1-TS |
| CN120G-500-ND | 3239-24-1-0500-007-1-TS |
| CN120G-50-ND | 3239-24-1-0500-007-1-TS |
| CN120L-100-ND | 3239-24-1-0500-005-1-TS |
| CN120L-250-ND | 3239-24-1-0500-005-1-TS |
| CN120L-25-ND | 3239-24-1-0500-005-1-TS |
| CN120L-500-ND | 3239-24-1-0500-005-1-TS |
| CN120L-50-ND | 3239-24-1-0500-005-1-TS |
| CN120R-100-ND | 3239-24-1-0500-004-1-TS |
| CN120R-250-ND | 3239-24-1-0500-004-1-TS |
| CN120R-25-ND | 3239-24-1-0500-004-1-TS |
| CN120R-500-ND | 3239-24-1-0500-004-1-TS |
| CN120R-50-ND | 3239-24-1-0500-004-1-TS |
| CN120W-100-ND | 3239-24-1-0500-002-1-TS |
| CN120W-250-ND | 3239-24-1-0500-002-1-TS |
| CN120W-25-ND | 3239-24-1-0500-002-1-TS |
| CN120W-500-ND | 3239-24-1-0500-002-1-TS |
| CN120W-50-ND | 3239-24-1-0500-002-1-TS |
| CN120Y-100-ND | 3239-24-1-0500-003-1-TS |
| CN120Y-250-ND | 3239-24-1-0500-003-1-TS |
| CN120Y-25-ND | 3239-24-1-0500-003-1-TS |
| CN120Y-500-ND | 3239-24-1-0500-003-1-TS |
| CN120Y-50-ND | 3239-24-1-0500-003-1-TS |
| CN682B-100-ND | 3239-16-1-0500-001-1-TS |
| CN682B-250-ND | 3239-16-1-0500-001-1-TS |
| CN682B-25-ND | 3239-16-1-0500-001-1-TS |
| CN682B-500-ND | 3239-16-1-0500-001-1-TS |
| CN682B-50-ND | 3239-16-1-0500-001-1-TS |
| CN683W-100-ND | 3239-16-1-0500-002-1-TS |
| CN683W-250-ND | 3239-16-1-0500-002-1-TS |
| CN683W-25-ND | 3239-16-1-0500-002-1-TS |
| CN683W-500-ND | 3239-16-1-0500-002-1-TS |
| CN683W-50-ND | 3239-16-1-0500-002-1-TS |
| CN684Y-100-ND | 3239-16-1-0500-003-1-TS |
| CN684Y-250-ND | 3239-16-1-0500-003-1-TS |
| CN684Y-25-ND | 3239-16-1-0500-003-1-TS |
| CN684Y-500-ND | 3239-16-1-0500-003-1-TS |
| CN684Y-50-ND | 3239-16-1-0500-003-1-TS |
| CN685R-100-ND | 3239-16-1-0500-004-1-TS |
| CN685R-250-ND | 3239-16-1-0500-004-1-TS |
| CN685R-25-ND | 3239-16-1-0500-004-1-TS |
| CN685R-500-ND | 3239-16-1-0500-004-1-TS |
| CN685R-50-ND | 3239-16-1-0500-004-1-TS |
| CN686L-100-ND | 3239-16-1-0500-005-1-TS |
| CN686L-250-ND | 3239-16-1-0500-005-1-TS |
| CN686L-25-ND | 3239-16-1-0500-005-1-TS |
| CN686L-500-ND | 3239-16-1-0500-005-1-TS |
| CN686L-50-ND | 3239-16-1-0500-005-1-TS |
| CN687N-500-ND | 3239-16-1-0500-006-1-TS |
| CN688G-100-ND | 3239-16-1-0500-007-1-TS |
| CN688G-250-ND | 3239-16-1-0500-007-1-TS |
| CN688G-25-ND | 3239-16-1-0500-007-1-TS |
| CN688G-500-ND | 3239-16-1-0500-007-1-TS |
| CN688G-50-ND | 3239-16-1-0500-007-1-TS |
| CN689A-100-ND | 3239-16-1-0500-008-1-TS |
| CN689A-250-ND | 3239-16-1-0500-008-1-TS |
| CN689A-25-ND | 3239-16-1-0500-008-1-TS |
| CN689A-500-ND | 3239-16-1-0500-008-1-TS |
| CN689A-50-ND | 3239-16-1-0500-008-1-TS |
| CN690V-500-ND | 3239-16-1-0500-010-1-TS |
