CNC Tech 3239-XX-1-0500-0XX-1-TS Length and Numbering
The 3239-xx cables from CNC Tech are available in several different lengths, however the manufacturer part number’s length spec of 500ft is static, for example if you want a 1,000ft spool that is not offered at this time, and attempting to order “3239-18-1-1000-004-1-TS” will not get you anywhere. That section of the part number does call out length, but it is not customizable unless you contact the manufacturer directly and negotiate a custom spool with them. There are some options available in a 100ft length from the manufacturer, but the majority arrive on 500ft spools and are cut down as needed at DigiKey.
As for the numbering system , the first “XX” in 3239-XX-1-0500-0XX-1-TS is used to call out wire gauge (Ranging from 10-24AWG) and the “0XX” calls out jacket color, as shown page 2 of the following datasheet:
Applicable Part Numbers
|CN120L-500-ND|3239-24-1-0500-005-1-TS|
|CN120Y-500-ND|3239-24-1-0500-003-1-TS|
|CN120W-500-ND|3239-24-1-0500-002-1-TS|
|CN118W-500-ND|3239-20-1-0500-002-1-TS|
|CN683W-500-ND|3239-16-1-0500-002-1-TS|
|CN682B-500-ND|3239-16-1-0500-001-1-TS|
|CN120B-500-ND|3239-24-1-0500-001-1-TS|
|CN104W-500-ND|3239-22-1-0500-002-1-TS|
|CN120R-500-ND|3239-24-1-0500-004-1-TS|
|CN104B-500-ND|3239-22-1-0500-001-1-TS|
|CN104R-500-ND|3239-22-1-0500-004-1-TS|
|CN118B-500-ND|3239-20-1-0500-001-1-TS|
|CN118R-500-ND|3239-20-1-0500-004-1-TS|
|CN105B-500-ND|3239-18-1-0500-001-1-TS|
|CN104L-500-ND|3239-22-1-0500-005-1-TS|
|CN104A-500-ND|3239-22-1-0500-008-1-TS|
|CN118L-500-ND|3239-20-1-0500-005-1-TS|
|CN118G-500-ND|3239-20-1-0500-007-1-TS|
|CN688G-500-ND|3239-16-1-0500-007-1-TS|
|CN689A-500-ND|3239-16-1-0500-008-1-TS|
|CN105GY-DS-ND|3239-18-1-0500-011-1-TS|
|CN120G-500-ND|3239-24-1-0500-007-1-TS|
|CN118Y-500-ND|3239-20-1-0500-003-1-TS|
|1175-3239-24-1-0500-011-1-TS-DS-ND|3239-24-1-0500-011-1-TS|
|CN104GY-DS-ND|3239-22-1-0500-011-1-TS|
|CN118GY-DS-ND|3239-20-1-0500-011-1-TS|
|1175-3239-16-1-0500-011-1-TS-DS-ND|3239-16-1-0500-011-1-TS|
|CN682B-100-ND|3239-16-1-0500-001-1-TS|
|CN120G-250-ND|3239-24-1-0500-007-1-TS|
|CN118B-250-ND|3239-20-1-0500-001-1-TS|
|CN105R-500-ND|3239-18-1-0500-004-1-TS|
|CN105L-500-ND|3239-18-1-0500-005-1-TS|
|CN685R-500-ND|3239-16-1-0500-004-1-TS|
|CN686L-500-ND|3239-16-1-0500-005-1-TS|
|CN104G-500-ND|3239-22-1-0500-007-1-TS|
|CN105G-500-ND|3239-18-1-0500-007-1-TS|
|CN104Y-500-ND|3239-22-1-0500-003-1-TS|
|1175-3239-14-1-0100-001-1-TS-ND|3239-14-1-0100-001-1-TS|
|1175-3239-14-1-0100-004-1-TS-ND|3239-14-1-0100-004-1-TS|
|1175-3239-14-1-0100-002-1-TS-ND|3239-14-1-0100-002-1-TS|
|1175-3239-14-1-0100-006-1-TS-ND|3239-14-1-0100-006-1-TS|
|1175-3239-14-1-0100-005-1-TS-ND|3239-14-1-0100-005-1-TS|
|1175-3239-12-1-0100-005-1-TS-ND|3239-12-1-0100-005-1-TS|
|1175-3239-12-1-0100-006-1-TS-ND|3239-12-1-0100-006-1-TS|
|1175-3239-12-1-0100-002-1-TS-ND|3239-12-1-0100-002-1-TS|
|1175-3239-12-1-0100-001-1-TS-ND|3239-12-1-0100-001-1-TS|
|1175-3239-12-1-0100-004-1-TS-ND|3239-12-1-0100-004-1-TS|
|1175-3239-10-1-0100-006-1-TS-ND|3239-10-1-0100-006-1-TS|
|1175-3239-10-1-0100-001-1-TS-ND|3239-10-1-0100-001-1-TS|
|1175-3239-10-1-0100-004-1-TS-ND|3239-10-1-0100-004-1-TS|
|1175-3239-10-1-0100-002-1-TS-ND|3239-10-1-0100-002-1-TS|
|1175-3239-10-1-0100-005-1-TS-ND|3239-10-1-0100-005-1-TS|
|CN120R-25-ND|3239-24-1-0500-004-1-TS|
|CN120B-25-ND|3239-24-1-0500-001-1-TS|
|CN120W-25-ND|3239-24-1-0500-002-1-TS|
|CN120Y-25-ND|3239-24-1-0500-003-1-TS|
|CN104A-25-ND|3239-22-1-0500-008-1-TS|
|CN118B-25-ND|3239-20-1-0500-001-1-TS|
|CN118W-25-ND|3239-20-1-0500-002-1-TS|
|CN118R-25-ND|3239-20-1-0500-004-1-TS|
|CN105B-25-ND|3239-18-1-0500-001-1-TS|
|CN105R-25-ND|3239-18-1-0500-004-1-TS|
|CN105A-25-ND|3239-18-1-0500-008-1-TS|
|CN105W-25-ND|3239-18-1-0500-002-1-TS|
|CN118L-25-ND|3239-20-1-0500-005-1-TS|
|CN120Y-50-ND|3239-24-1-0500-003-1-TS|
|CN120G-50-ND|3239-24-1-0500-007-1-TS|
|CN120R-50-ND|3239-24-1-0500-004-1-TS|
|CN120L-50-ND|3239-24-1-0500-005-1-TS|
|CN120G-25-ND|3239-24-1-0500-007-1-TS|
|CN120L-25-ND|3239-24-1-0500-005-1-TS|
|CN120W-50-ND|3239-24-1-0500-002-1-TS|
|CN104L-50-ND|3239-22-1-0500-005-1-TS|
|CN104R-50-ND|3239-22-1-0500-004-1-TS|
|CN105G-25-ND|3239-18-1-0500-007-1-TS|
|CN105L-25-ND|3239-18-1-0500-005-1-TS|
|CN105Y-25-ND|3239-18-1-0500-003-1-TS|
|CN682B-25-ND|3239-16-1-0500-001-1-TS|
|CN685R-25-ND|3239-16-1-0500-004-1-TS|
|CN683W-25-ND|3239-16-1-0500-002-1-TS|
|CN686L-25-ND|3239-16-1-0500-005-1-TS|
|CN118B-50-ND|3239-20-1-0500-001-1-TS|
|CN118R-50-ND|3239-20-1-0500-004-1-TS|
|CN118W-50-ND|3239-20-1-0500-002-1-TS|
|CN118L-50-ND|3239-20-1-0500-005-1-TS|
|CN688G-25-ND|3239-16-1-0500-007-1-TS|
|CN120Y-100-ND|3239-24-1-0500-003-1-TS|
|CN120B-100-ND|3239-24-1-0500-001-1-TS|
|CN120R-100-ND|3239-24-1-0500-004-1-TS|
|CN120G-100-ND|3239-24-1-0500-007-1-TS|
|CN120L-100-ND|3239-24-1-0500-005-1-TS|
|CN105B-50-ND|3239-18-1-0500-001-1-TS|
|CN105L-50-ND|3239-18-1-0500-005-1-TS|
|CN105W-50-ND|3239-18-1-0500-002-1-TS|
|CN105R-50-ND|3239-18-1-0500-004-1-TS|
|CN118Y-50-ND|3239-20-1-0500-003-1-TS|
|CN120W-100-ND|3239-24-1-0500-002-1-TS|
|CN104R-100-ND|3239-22-1-0500-004-1-TS|
|CN104B-100-ND|3239-22-1-0500-001-1-TS|
|CN104W-100-ND|3239-22-1-0500-002-1-TS|
|CN105G-50-ND|3239-18-1-0500-007-1-TS|
|CN105Y-50-ND|3239-18-1-0500-003-1-TS|
|CN105A-50-ND|3239-18-1-0500-008-1-TS|
|CN682B-50-ND|3239-16-1-0500-001-1-TS|
|CN686L-50-ND|3239-16-1-0500-005-1-TS|
|CN118R-100-ND|3239-20-1-0500-004-1-TS|
|CN118W-100-ND|3239-20-1-0500-002-1-TS|
|CN118B-100-ND|3239-20-1-0500-001-1-TS|
|CN104A-100-ND|3239-22-1-0500-008-1-TS|
|CN104L-100-ND|3239-22-1-0500-005-1-TS|
|CN104Y-100-ND|3239-22-1-0500-003-1-TS|
|CN104G-100-ND|3239-22-1-0500-007-1-TS|
|CN685R-50-ND|3239-16-1-0500-004-1-TS|
|CN683W-50-ND|3239-16-1-0500-002-1-TS|
|CN105R-100-ND|3239-18-1-0500-004-1-TS|
|CN105B-100-ND|3239-18-1-0500-001-1-TS|
|CN105Y-100-ND|3239-18-1-0500-003-1-TS|
|CN118Y-100-ND|3239-20-1-0500-003-1-TS|
|CN118G-100-ND|3239-20-1-0500-007-1-TS|
|CN118L-100-ND|3239-20-1-0500-005-1-TS|
|CN120B-250-ND|3239-24-1-0500-001-1-TS|
|CN120R-250-ND|3239-24-1-0500-004-1-TS|
|CN688G-50-ND|3239-16-1-0500-007-1-TS|
|CN105W-100-ND|3239-18-1-0500-002-1-TS|
|CN105G-100-ND|3239-18-1-0500-007-1-TS|
|CN105L-100-ND|3239-18-1-0500-005-1-TS|
|CN105A-100-ND|3239-18-1-0500-008-1-TS|
|CN685R-100-ND|3239-16-1-0500-004-1-TS|
|CN686L-100-ND|3239-16-1-0500-005-1-TS|
|CN104R-250-ND|3239-22-1-0500-004-1-TS|
|CN688G-100-ND|3239-16-1-0500-007-1-TS|
|CN120Y-250-ND|3239-24-1-0500-003-1-TS|
|CN120W-250-ND|3239-24-1-0500-002-1-TS|
|CN120L-250-ND|3239-24-1-0500-005-1-TS|
|CN118L-250-ND|3239-20-1-0500-005-1-TS|
|CN118R-250-ND|3239-20-1-0500-004-1-TS|
|CN104L-250-ND|3239-22-1-0500-005-1-TS|
|CN104B-250-ND|3239-22-1-0500-001-1-TS|
|CN104G-250-ND|3239-22-1-0500-007-1-TS|
|CN104W-250-ND|3239-22-1-0500-002-1-TS|
|CN104Y-250-ND|3239-22-1-0500-003-1-TS|
|CN104A-250-ND|3239-22-1-0500-008-1-TS|
|CN105B-250-ND|3239-18-1-0500-001-1-TS|
|CN118Y-250-ND|3239-20-1-0500-003-1-TS|
|CN118W-250-ND|3239-20-1-0500-002-1-TS|
|CN118G-250-ND|3239-20-1-0500-007-1-TS|
|CN105Y-250-ND|3239-18-1-0500-003-1-TS|
|CN105L-250-ND|3239-18-1-0500-005-1-TS|
|CN105G-250-ND|3239-18-1-0500-007-1-TS|
|CN682B-250-ND|3239-16-1-0500-001-1-TS|
|CN104N-500-ND|3239-22-1-0500-006-1-TS|
|CN105R-250-ND|3239-18-1-0500-004-1-TS|
|CN688G-250-ND|3239-16-1-0500-007-1-TS|
|CN686L-250-ND|3239-16-1-0500-005-1-TS|
|CN105W-500-ND|3239-18-1-0500-002-1-TS|
|CN105Y-500-ND|3239-18-1-0500-003-1-TS|
|CN105A-500-ND|3239-18-1-0500-008-1-TS|
|CN684Y-500-ND|3239-16-1-0500-003-1-TS|
|CN104GY-500-ND|3239-22-1-0500-011-1-TS|
|CN118GY-500-ND|3239-20-1-0500-011-1-TS|
|CN105GY-500-ND|3239-18-1-0500-011-1-TS|
|CN104G-25-ND|3239-22-1-0500-007-1-TS|
|CN104R-25-ND|3239-22-1-0500-004-1-TS|
|CN104B-25-ND|3239-22-1-0500-001-1-TS|
|CN104Y-25-ND|3239-22-1-0500-003-1-TS|
|CN104L-25-ND|3239-22-1-0500-005-1-TS|
|CN104W-25-ND|3239-22-1-0500-002-1-TS|
|CN118G-25-ND|3239-20-1-0500-007-1-TS|
|CN120B-50-ND|3239-24-1-0500-001-1-TS|
|CN104B-50-ND|3239-22-1-0500-001-1-TS|
|CN104A-50-ND|3239-22-1-0500-008-1-TS|
|CN104W-50-ND|3239-22-1-0500-002-1-TS|
|CN104Y-50-ND|3239-22-1-0500-003-1-TS|
|CN104G-50-ND|3239-22-1-0500-007-1-TS|
|CN684Y-25-ND|3239-16-1-0500-003-1-TS|
|CN118Y-25-ND|3239-20-1-0500-003-1-TS|
|CN689A-25-ND|3239-16-1-0500-008-1-TS|
|CN118G-50-ND|3239-20-1-0500-007-1-TS|
|CN689A-50-ND|3239-16-1-0500-008-1-TS|
|CN684Y-50-ND|3239-16-1-0500-003-1-TS|
|CN689A-100-ND|3239-16-1-0500-008-1-TS|
|CN683W-100-ND|3239-16-1-0500-002-1-TS|
|CN684Y-100-ND|3239-16-1-0500-003-1-TS|
|CN105W-250-ND|3239-18-1-0500-002-1-TS|
|CN105A-250-ND|3239-18-1-0500-008-1-TS|
|CN685R-250-ND|3239-16-1-0500-004-1-TS|
|CN683W-250-ND|3239-16-1-0500-002-1-TS|
|CN684Y-250-ND|3239-16-1-0500-003-1-TS|
|CN689A-250-ND|3239-16-1-0500-008-1-TS|
