Good afternoon I would like help with a part to extend a 4mm coaxial cable. This is to lengthen it. Can anyone help please.
Hello Joe,
Welcome to the Digikey Tech forum.
These are a list of SMA coax cables we have available.
Continuing the discussion from Coax 4mm extention addapter:
this is the coaxial wire.So sorry I only need the fitting as the garage has the 4mm coaxial cable.
Continuing the discussion from Terminal block replacement:
Hi lindsay can you help me please.
can you give me part numbers for these fittings pleaseLooks like a SMB female socket plug, here’s the options I found.
Do you have a Male and female connection please. Thankyou very much.
Here are some mating options.
