No part numbers for me to go on. I did my best checking out the Digi-key site, but was unable to find a compatible replacement. Please help.
Do you have a part number or marking on the part, or can you explain the part what it is?
No part number. It joins what I suspect is a standard barrel (male) to two low voltage wires. I can measure the OD of the male barrel connector if that would help.
it sort odf looks like
2234-LS-00015-ND
Is that not available on digikey.ca? I can search for it and find it elsewhere on the net and find it, but isn’t showing up in a search on digikey.ca
ok sadly no Looks like US only
Alright, thanks for your help. Response speed was impressive, much appreciated!
