Connector Cap Housing
Could You please suggest a suitable Connector Cap housing for the part number RT062448SNH
so that I can cover that connector when it is not in use.
Hello balabhaskar.vg,
I’m sorry, but I do not see a sealing cap for this plug.
The only option to protect the connector, when not in use, would be to connect it to an unused mating connector, like RT002448PNH-ND.
Thank You David,
Can we Use some other means other than using the mating Connector .
Looks like there are caps for this series but not for that shell size.
I’m not sure how else you could cover it other than what David suggested. Maybe 3D print something that would fit if you have the means.
Thank you Sir,
let me see to it and I will let you know
