Going nuts looking for matches for these. Pins are 0.6mm. Pitch is 2mm. “Tooth” at T is 0.6mm. Depth A is 4mm, though 4.6 over the tooth. B is 7.95mm.
Hejsan @mattias.fagerlund ,
This is likely HDGC2007 by SZHDGC.
AMP/TE-conn carries similarish part.
179228-3 TE Connectivity AMP Connectors | Rectangular Connector Housings | DigiKey
Cheers, heke
Thanks, those look to match. Do you know if they are they compatible with eachother?
Hi @mattias.fagerlund ,
There is no chance to confirm 100% compatibility from pictures alone.
I’d say just purchase a few AMP/TE housings from DigiKey and test. You’ll need to buy the contacts and some crimping pliers too, if you plan to make your own harness.
Cheers, heke
