I need some assistance identifying the corresponding connector that would mate with this oval/rectangular connector. It is 3 pin male housing with female pins. I am interested in the corresponding female housing with male pins to interface with it.
I could not come up with a part number for this one.
I had a look through all our three position connectors, I also could not find a match on this.
Looking for the female connector plug that fits into 2-pin socket on a 12 volt lead-acid battery used in the Brinkmann Q-Beam spotlight. Just need to identify the plug that is part of the 12VDC transformer. Thanks.
Hi,
Welcome to the Digikey tech forum. I did some searching and wasn’t able to find a replacement connector in our system that matches the one you have.
Steve - thanks for confirming, and for the assurance that I wasn’t completely incompetent. I’ll try to make something that’ll work then. Much obliged.
