Hello. I have a Gen 4 Mr Cool mini-split unit and it has an aux. male pigtail for connection for a system disable switch.Im having trouble locating a matching female connectors with wires attached.The pins are flat and 2.5mm apart center-center. It has a flat plastic latch on the side.
AI STATED:The item number 406114963740 is for the Molex 52213-0211 Mizu-P25 Series Receptacle Housing. This is exactly the component line used by premier HVAC brands for their low-voltage auxiliary and factory sensor runs because they are exceptionally compact, handle thermal cycling, and provide an IP67 waterproof seal to prevent condensation shorts.
Please help me identify the matching female connectors. Thank you
