Corne Split Keyboard PCB
Hi all, I’m new to DigiKey and would like some advice before I submit the files to print a pcb for my keyboard.
Background
I want to build a corne split keyboard. There are two versions of this keyboard, cherry and chocolate. Cherry refers to Cherry MX style switches and chocolate is another type of switch which requires a different PCB. I want to build a Cherry MX style corne keyboard following this building guide:
Here is the location to the cad and jlpcb files:
I’m not at all sure how to proceed with DigiKey service, if someone can advice on the services available (i.e. what services DigiKey can provide i.t.o. this project) that would be much appreciated.
Hello Dronkwors and welcome to the DigiKey TechForum.
After reviewing the links, I did come up with a couple links that may help you.
For the PCB itself, we do have the PCB Builder.
We also do have these Design and Integration Services, which would be firms that offer fee-based design, development, prototyping, manufacturing, automation control, and system integration services.
We also may be able to provide assistance in finding the components that you would require to complete this build.
Hello dronkwars,
Thank you for your inquiry.
The file types at the Github repository you linked are Kicad format project files.
They would need to be used to export within Kicad fabrication files they call Gerbers.
I provided a tutorial on how to do this, I believe a version of Kicad or two ago, which can be found here:
Tutorial for Generating KiCad Design Files (Gerbers) for DKRed - Design Tools and Resources / DKRed and PCB Builder - Electronic Component and Engineering Solution Forum - TechForum │ DigiKey
