Hi, I broke my current power supply for the Digi Anywhere USB/2 (G2) and am trying to figure out which one would be the correct one to buy as a replacement. I’m pretty sure the unit still works but the power supply is just broken. The unit fell out of our server rack and I think the device still functions, but the power supply connector bent and no longer makes a complete full connection to the hardware.
This is the tech information I have for the Power Supply which looks like it is manufactured by Globtek, Inc. The spec info is 5VDC @3AMPS max with locking barrel. Thank you if anyone knows the correct one for this!
Hello rendex - welcome to the Forum community! We do have the part number you mentioned, 1939-WR9QA3000L9PCIMR6B-ND but there is currently no stock. This is a possible substitute that is in stock 102-3572-ND. If you are in North America and don’t need the adapters for the input connector, we have these options which are also in stock.
Jenny, thank you for your quick reply. I looked at those and chose to buy one of the 2 you had mentioned last. I don’t remember which one. One thing I forgot about the unit as I dont have it in front of me is that it has a twist lock plug. Do you think that will still work with this unit? I have attached a picture I found of what the twist lock barrel connector looks like. Do you think this would still work for this unit with the twist lock?
Attached is the spec sheet for the power supply that is shipped with the unit that I received directly from Digi USB Anywhere Tech Support for USB Anywhere 2 (G2)
@Ryan_2724 Does the one you posted fit these specs?
Thanks for your reply. According to that document, it lists a 2.1 x 5.5mm positive center barrel connector. Click here for a recommended North American alternative 237-1419-ND. Click here for a recommended International alternative 237-2133-ND. These should work although they are not the thread lock style.
In the rare instances documentation is incorrect, and you’d like to be sure before ordering, you can take a look at this post which only requires a pen, a toothpick, or a DMM test lead to measure the inner diameter wall adapter barrel of the power supply you currently have:
