Looking to use the CUI Devices Fan CFM-6010C-150-326-22 but can’t find the connector to use on the PCB. Can you tell me what the connector is and what the mating connector on PCB is (Surface Mount is preferred)
Hi @dirkvandereep62 ,
Per datasheet, this fan does not arrive with a connector installed. Connector mating set would depend on specifications of your circuit board if you are able to provide them.
