We need a mating connector to connect the fan Digi-Key part no.
603-2240-ND. Can you tell us a connector type?
Kind regards
Christoph
Hi,
Welcome to the Digikey tech forum. This looks to be a common 2.54mm pitch connector . Check these pin header options for one that best suits your needs.
Hello Steve,
Thank you for your quick reply. Unfortunately, the pin headers you
suggested do not have polarity protection.
The fan connector has a polarity protection with two asymetric tracks.
So we need a pin header with polarity protection that fits to this tracks.
I would appreciate if you could make any other suggestions on this.
Anyhow, thank you very much for your support.
Best regards
Christoph
The Molex 0470533000 would appear compatible.
