Thanks a lot for taking care of my consultation.
In a device with a hall sensor, I don’t know where the +5V, GND and signal cables belong in the connector. Can I damage it if I don’t connect it correctly?
Greetings,
Some devices include protections against incorrect connection, others do not. Without reliable information saying otherwise, one should assume that a device will be damaged by incorrect connection.
Thank you very much for the reply. Greetings
