hi Good day,
we would like to seek your expertise regarding date code instruction for Eaton products.
we have here EFDKS60K186D132LH with a date code characters G33. would you know what is the equivalent year for G? and if there is a supporting documents. thank you.
Hello @logietec ,
Welcome to the TechForum! Thank you for the question.
As you rightfully identified, Eaton EFDKS60K186D132LH datasheet represent the date code format as YWW, where “Y” represents the year code and “WW” represents the production/work week. However this datasheet itself does not provide a year-code lookup table.
However in the Product Change Notification to Eaton Electronics PowerStor Supercapacitor Customers, Eaton mentions as an example that in yww code, W=2013, X=2014(If I dare extrapolate it could mean that Z=2016.
And if we assume that it will follow the same trend, the following could be assumed,
A=2017, B=2018 and G=2023.(This is consistent with the Bussmann series product date code as explained below).
According to Eaton Bussmann series product date code explanation also, G=2023.
Based on these references, G33 is consistent with week 33 of 2023. However, the available documents do not explicitly confirm that the Eaton Bussmann year-letter mapping or the Supercapacitor Product Change Notification also applies to the EFDKS film-capacitor family.
Thus I cannot say with full confidence that G refers to 2023. As a result, please exercising caution before definitively interpreting “G” as 2023
Additionally,
If you require the Date code to be within a specific time, for your next order with DigiKey, you could specify those requirements in the order notes at the time of order.
If the date code is in your order notes, our warehouse will fill your order with the appropriate stock. And if that is not possible, our customer service team will contact you to see if the date code we do have is acceptable by you or if you would like to cancel that part of the order.
Please refer the following link for additional information.
Specific Date Code Requirements & Lot Code Requests
