Travis,
What PV and thermo-electric sources would you recommend to use with this board?
Thanks
Ed
Hi Yabusame,
For thermo electric generators I would definitely suggest the Marlow Industries Mini Harvester 1681-1087-ND.
Let me know if you have any other questions.
@Yabusame,
Just in case by PV you were meaning Photo Voltaic I would also like to suggest Panasonic’s PV cells. AM-1417CA. I have not used these personally but it looks like they would interface with the board the best.
DigiKey P/N: 869-1000-ND
Yes, that was photovoltaic. Thanks.
To add to what @TWeesner said, the Panasonic AM-1xxx solar cells are for indoor applications at low light levels. I’ve used them and they work quite well for their intended purpose.
ben,
This may become a crucial criterium for me. We have a lot of old houses here with relatively small windows and quite thick walls, up to 70 cm.
