This article is practically one-to-one with “Getting started with the DE0-Nano-Soc”.
Same patch “0001-de0_nano0fixes.patch” is applied to the u-boot sources, same “socfpga_de0_nano_soc_defconfig” is used to configure the u-boot.
Is it a mistake, or exactly the same final build would work for both DE10-Nano and DE0-Nano-SoC kits?
Hi @Vlad correct, at the time i originally messed with this board, u-boot did have two different targets, however for some reason the target tied to this board actually failed to boot… While the other defconfig worked fine. I bet today, that issue is resolved, and the proper defconfig would be needed on a much newer branch…
