Hi, I used your instructions to build an image for De0 Nano Soc Kit, and it works well.
However, the uboot-with-spl.sfp, while it works to boot to Linux, does not manage the loading of FPGA *.rbf file.
If I have an FPGA file I want to load on boot, the “normal” approach from Intel/Altera as recommended by the GSRD releases is to use their SoCEDS tools to generae a makepimage.bin for the SPL and build Uboot from their local tar of an old/Altera modded uboot. I want to use the latest U-boot, but these modifications to allow FPGA loading (including the FPGA handoff code/etc) does not appear to be in your patches.
Is this possible on the latest U-boot, or do I need to revert to the older Altera/Intel toolchain?
@petesmudge, sadly today we still have to use the older Altera/Intel toolchain. Patches have been posted to the u-boot mailing list, but last i checked they haven’t been fully integrated yet. So we are getting “very” close to FPGA loading on mainline u-boot…
Thanks for the reply - I would be very interested to see this become available, as it would make maintaining the codebase more optimal if I can just patch settings changed by the FPGA to my u-Boot tree and build it all in uBoot without having to do a full SoCEDS install and manual/GUI based steps.
Hello Robert! First of all, thank you so much for this article - it really helped and saved a lot of time. I used it to create Linux image for our De0-Nano-based hardware, and Linux part was launched and is working without any problem - everything just fine.
My question is the same as the Pete’s… how can we init FPGA with custom RBF-configuration on a u-boot stage now? As far as I figured out Intel/Altera’s codebase is a bit behind u-boot’s “trunk”. Anyway, could you please point me how to make our new U-boot/Linux system and FPGA behave like friends? Pete had mentioned about Altera’s toolchain but I’m really new to this topic and need a huge kick in a right direction.
@RobertCNelson, I tried both your images but it seems something is not correct when writing to SD card.
I have tried different SD card and with that one I can’t see any log on console.
Created a new DOS disklabel with disk identifier 0x681993a3.
/dev/sdb1: Created a new partition 1 of type ‘Unknown’ and of size 1 MiB.
/dev/sdb2: Created a new partition 2 of type ‘Linux’ and of size 3.7 GiB.
/dev/sdb3: Done.
New situation:
Disklabel type: dos
Disk identifier: 0x681993a3
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 4095 2048 1M a2 unknown
/dev/sdb2 * 4096 7626751 7622656 3.7G 83 Linux
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
nws@ubuntu:~/Documents$ sudo dd if=./altera/rcn/u-boot-2019.01-with-spl.sfp of=${DISK}1
1606+1 records in
1606+1 records out
822649 bytes (823 kB, 803 KiB) copied, 0.913883 s, 900 kB/s
And then I take SD card out of USB card reader and insert in the SD card slot of DE0-Nano-SoC kit
Thanks for testing @ankurt, this is starting to look like a hardware change introduced in Rev D boards. What images currently work for you? I’ve started digging thru terasic’s docs: downloads
Edit, i don’t see any changes to the memory interface or the modules utilized.
