@RobertCNelson, it was purchased about 1 month ago
@ankurt, I have another build for you to test:
U-Boot SPL 2019.04-rc1-dirty (Feb 15 2019 - 10:27:47 -0600)
Trying to boot from MMC1
U-Boot 2019.04-rc1-dirty (Feb 15 2019 - 10:27:47 -0600)
CPU: Altera SoCFPGA Platform
FPGA: Altera Cyclone V, SE/A4 or SX/C4, version 0x0
BOOT: SD/MMC Internal Transceiver (3.0V)
DRAM: 1 GiB
MMC: dwmmc0@ff704000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: Terasic DE-0(Atlas)
Net:
Error: ethernet@ff702000 address not set.
eth-1: ethernet@ff702000
Hit any key to stop autoboot:
Please test:
wget -c https://github.com/eewiki/u-boot-testing/raw/master/socfpga_de0_nano_soc/u-boot-2019.04-rc1-with-spl.sfp
sudo dd if=./u-boot-2019.04-rc1-with-spl.sfp of=${DISK}1
If this version doesnāt work, you should contact the re-seller who sold you the board and request what changes they made vs the older Rev Cās.
Regards,
Hello, Robert!
Forgive me, please, for such a huge delay. Here is actual projectās chronicle:
- After your tips in January I became able to finally launch the new UBoot+Linux pair on a Terasic de0-nano dev-board. I got all the updates, installed and adjusted all the specific required software and so on.
- Two weeks ago we received the custom hardware. It has almost the same schematics as DE0 board rev. C0 except the RAM size. The custom board has only 512 MBytes - e.g. twice less than DE0.
- Obviously, U-Boot wouldnāt start on a new hardware - DDRAM calibration procedure on a early startup is not passing.
- I started to dive into U-Boot sourcetree internals, trying to replace the existing terasic-related files with my own, generated right from the Intel QSys.
- At some point in time the U-Boot started to pass the memory calibration, but began to fail at memory size checking.
- Now itās saying that I have only 8 Mbytes of RAM - not 512 as Iām expecting. Consequently it doesnāt let the Linux to boot up.
Iāve rechecked all the SDRAM-related settings in QSys - everything seems fine from that side. I guess I need to adjust/edit/replace something in u-boot source tree. Have you ever faced similar issues? Could you please share some of your priceless tips with me once again?
Thank you in advance, sir!
P.S: I should note that the āoldā linux boots on a custom board with success - so itās not a hardware related issue for sure
@AlexeyG, Sorry, iām not the expert on the SOCFPGA memory initialization in u-boot.
First double check your qts files:
Thereās quiet a few magic numbers, so if you only changed the memory, try to limit your customizations.
Then, double check the memory value on the dts:
and finally, in this config:
Finally, double check that none of these hard-coded offsetās end up above 512Mb:
Regards,
@RobertCNelson
Hi. I followed your tutorial on installing a ubuntu 18.04 LTS on the de0-nano-soc. The system works fine but the fpga part seems to not work correctly. Previously on debian system I would just use the dd command to flash the fpga and access the shared memory. However on the newly built ubuntu accessing the shared memory of fpga woule give a bus error. I am very confused, would you help?
Also in the /sys/class/fpga/fpga0/ there suppose to be a status that says user mode, but such status does not exist in the ubuntu system.
@AK107bis, thatās odd as we just pull in Alteraās kernel:
any chance on your working system, can you grab the kernel version and itās kernel config?
Regards,
@RobertCNelson Thank you very much for the write-up. Still - after few years - it is a lifesaver. (Especially since many links in other tutorials from the āLatera Daysā are broken).
I followed your original article to build bootable image with Ubuntu. Then I spent most of the rainy Saturday making the FPGA load. Switching between the Terasic Yocto and Debian. Works now
I have two questions though:
a) To make the FPGA load from the .rbf file at u-boot I made some (uneducated?) changes to the u-boot env variables - overwriting bootcmd=run loadfpga
setenv loadfpga run loadfpgaimage\; run loadfpganow
setenv loadfpgaimage load mmc 0:2 ${fpgaloadaddr} ${fpgaimage}
setenv loadfpganow fpga load 0 ${fpgaloadaddr} ${filesize}
setenv fpgaimage /boot/de0_default.rbf
setenv fpgaloadaddr 0x2000000
Is this a āhackā or is it close to what is intended?
b) The Device Tree / Device Tree Overlay has different structure between the two OS versions.
On the Yocto Linux I was able to load the image from within the OS: dd if=DE0_NANO_SOC_Default_MV_PP16.rbf of=/dev/fpga0 bs=1M
What is the corresponding way of doing the same on the Debian built per your instructions?
Thanks - M.
