All of the equipment that is calibrated from Desco Industries comes with a Certificate of Calibration. Desco’s NIST traceable calibration consists of:
• A product that is calibrated to meet Desco’s published specifications
• A printed certificate is provided stating that Desco uses accepted procedures and standards traceable to the National Institute of Standards and Technology
• A calibration certificate will normally consist of a model number, serial number, date, and the signature of the technician that performed the calibration
• A calibration sticker applied to the product listing the identification number, the calibration date, and the initials of the technician performing the calibration
If the Calibration Certificate has been misplaced, a duplicate can be printed by entering both the Model & Serial number on this link https://desco.descoindustries.com/Calibration-Certificate.aspx.
If the equipment needs basic recalibration, please go to https://desco.descoindustries.com/Calibration-Procedure.aspx. If the traceable calibration is needed, it is recommended to contact the manufacturer directly. The calibration pricing is listed at https://desco.descoindustries.com/Calibration-Pricing.aspx
Click Here for Desco equipment that includes the certificate
Desco Part Numbers
| Description | Digikey Part Number | Manufacturer Part Number |
| ANLG SRFC RESIS METER | 19786-ND | 19786 |
| BODY VOLTAGE METER | 16-19431-ND | 19431 |
| CALIB UNIT CONST WRKSTN TESTER | 16-1283-ND | 98220 |
| CALIBRATION UNIT NIST STD WS&FG | 16-1272-ND | 7010 |
| CHARGED PLATE ANALYZER, 6’‘X6’', | 50571-ND | 50571 |
| COMBO TESTER X3 120VAC | 62101-ND | 62101 |
| COMBO TESTER X3 PLUS, WITH DUAL | 16-19265-ND | 19265 |
| COMBO TESTER X3, TESTER ONLY | 19275-ND | 19275 |
| COMBO TESTER X3/STAND | 16-19271-ND | 19271 |
| DIGITAL SURFACE RESIST METER | 16-1578-ND | 19291 |
| DIGITAL SURFACE RESIST METER KIT | 16-1577-ND | 19290 |
| DL OP CONT MNTR W/WRST STP 120V | 50522-ND | 50522 |
| DUAL-WIRE DUAL OPERATOR MONITOR | 16-19662-ND | 19662 |
| ESD WORKSTATION MONITOR | 16-1203-ND | 19325 |
| FULL-TIME CONTINUOUS MONITOR, 22 | 19326-ND | 19326 |
| FULL-TIME MONITOR, WITH NORTH AM | 16-19321-ND | 19321 |
| FULL-TIME MONITOR, WITH UK POWER | 16-19322-ND | 19322 |
| GLOVE CONSTANT AREA AND FORCE EL | 16-19298-ND | 19298 |
| IONIZATION TEST KIT | 16-1596-ND | 19493 |
| KIT COMPLETE FLD METER/ION TEST | 19497-ND | 19497 |
| KIT COMPLETE FLD MTR/ION TEST | 19447-ND | 19447 |
| KIT METER RES DIG TEMP/HUMIDITY | 19780-ND | 19780 |
| LIMIT COMPARATOR DUALWIRE MONITO | 62170-ND | 62170 |
| LIMIT COMPARATOR, FOR DUAL WIRE | 50524-ND | 50524 |
| METER STATIC FIELD DIG CHPD | 19445-ND | 19445 |
| MINI MONITOR JEWEL KIT N AMERICA | 16-1391-ND | 19242 |
| MINI MONITOR JEWEL NORTH AMERICA | 16-1390-ND | 19239 |
| MINI MONITOR POWER ADAPTER UNIV | 16-1392-ND | 19243 |
| MNTR GND GRD 4.5 W/BZZR-SW 120VA | 16-1576-ND | 94392 |
| MNTR GND GRD 4.5 W/BZZR-SW GND | 94390-ND | 94390 |
| MNTR GND GRD 5 W/BZZR-SW 120VAC | 94393-ND | 94393 |
| MNTR GND GRD 5 W/BZZR-SW GND | 94391-ND | 94391 |
| MNTR MLT-MNT 120VAC W/WRST STRP | 19229-ND | 19229 |
| MNTR MLT-MNT 220VAC W/WRST STRP | 19234-ND | 19234 |
| MNTR MLT-MNT 220VAC W/WRST STRP | 19236-ND | 19236 |
| MONITOR BODY VOLTAGE | 16-1223-ND | 19241 |
| MONITOR CONT MULTI-MOUNT | 16-1163-ND | 19228 |
| MONITOR CONTINUOUS WORKSTATION | 19222-ND | 19222 |
| MONITOR CONTINUOUS WORKSTATION | 19223-ND | 19223 |
| MONITOR CONTINUOUS WORKSTATION | 19224-ND | 19224 |
| MONITOR CUSTOM OVERLAY/WS | 16-1593-ND | SPI-20686 |
| MONITOR DUAL OPERATOR 120V | 16-1204-ND | 19246 |
| MONITOR DUAL WIRE CONTINOUS 120V | 16-1303-ND | 19665 |
| MONITOR DUAL WORKSTATION 120V | 16-1082-ND | 19230 |
| MONITOR GROUND HUB US | 16-1162-ND | 19219 |
| MONITOR MINI ZVM N AMERICA | 16-1160-ND | 19101 |
| MONITOR MINI ZVM N AMERICA | 19102-ND | 19102 |
| MONITOR NO AMERICA PWR ADAPTER | 16-1387-ND | 19651 |
| MONITOR UNIVERSAL PWR ADAPTER | 16-1388-ND | 19652 |
| MONITOR W/SPLIT REMOTE MOD 120V | 16-1117-ND | 19232 |
| MONITOR WORKSTATION JEWEL MINI | 16-1161-ND | 19218 |
| MONITOR WORKSTATION MINI 120V | 16-1083-ND | 19212 |
| MONITOR WRISTSTRAP/WRKSTN 120V | 19210-ND | 19210 |
| MONITOR, PROGRAMMABLE, DUAL W/2 | 50515-ND | 50515 |
| MONITOR, ZERO VOLT, WITH 2 WRIST | 50537-ND | 50537 |
| MONITOR, ZERO VOLT, WITH 2 WRIST | 50538-ND | 50538 |
| MONITR CONTINUOUS MULTI-MNT 120V | 16-1116-ND | 19226 |
| SMARTLOG V5 | 50766-ND | 50766 |
| SRFC RESISTANCE METER | 19788-ND | 19788 |
| STATIC FIELD METER, DIGITAL | 16-1438-ND | 19492 |
| STATIC LOCATOR DIGITAL | 16-1165-ND | 19430 |
| STATIC LOCATOR W/O BATTERY PACK | 19444-ND | 19444 |
| SURFACE RESISTANCE CHECKER | 16-1602-ND | 19640 |
| SURFACE RESISTANCE METER KIT | 16-1308-ND | 19787 |
| TEST KIT SURFACE RESISTANCE | 16-1166-ND | 19784 |
| TEST KIT UPGRADE PORT IONIZERS | 16-1502-ND | 19440 |
| TESTER AC OUTLET & WRIST STRAP | 16-1232-ND | 98130 |
| TESTER AC OUTLET & WRIST STRAP | 98131-ND | 98131 |
| TESTER CALIB FORGROUND GARD 4.5 | 94335-ND | 94335 |
| TESTER CALIBRATION | 94370-ND | 94370 |
| TESTER CALIBRATION | 94371-ND | 94371 |
| TESTER CALIBRATION FORGROUND | SPI-20780-ND | SPI-20780 |
| TESTER COMBO | 16-1605-ND | 19270 |
| TESTER COMBO WS & FG NIST | 16-1256-ND | 19250 |
| TESTER COMBO WS & FG NIST | 16-1285-ND | 19280 |
| TESTER COMBO WS & FG W/STAND | 16-1084-ND | 19252 |
| TESTER COMBO WS&FS W/ PLATE | 16-1098-ND | 19253 |
| TESTER COMBO WTH SS FOOT PLATE | 16-1287-ND | 19283 |
| TESTER COMBO WTH STAND & FOOTPLA | 16-1286-ND | 19282 |
| TESTER COMBO X3 | 16-1490-ND | 19278 |
| TESTER COMBO X3 | 16-1594-ND | 19279 |
| TESTER COMBO X3 WITH STAND | 19277-ND | 19277 |
| TESTER FOOTWEAR WITH PLATE 120V | 62090-ND | 62090 |
| TESTER LOW RESISTANCE | 16-1164-ND | 19245 |
| TESTER MINIMEG 9VDC NIST | 19635-ND | 19635 |
| TESTER SOLDERING TIP VOLTAGE | 35110DC-ND | 35110 |
| TESTER W/S 2 ST TOUCH W/220V | 19351-ND | 19351 |
| TESTER W/S 2 STATE TOUCH NIST | 16-1233-ND | 19350 |
| TESTER X3 COMBO PROG W/DL PLATE | 19276-ND | 19276 |
| TSTR AC OTLT-WRST STRP 120VAC | 16-1351-ND | 98132 |
| VERIFICATION TESTER WAVE DISTORT | 16-1508-ND | 98221 |
| VERIFICATION TESTER, FOR GROUND | 94372-ND | 94372 |
| VERIFICATION TESTER, FOR GROUND | 94373-ND | 94373 |
| WRISTSTRAP TESTER 9V OPERATION | 16-1089-ND | 19240 |
| ZERO VLT MNTR W/WRST STP KT 120V | 16-1496-ND | 50528 |
| ZERO VOLT MONITOR | 16-19668-ND | 19668 |
| ZVM SOLO DL-WR CONT MONITOR | 50576-ND | 50576 |
| LOW RESISTANCE TESTER | 16-1322-ND | 19249 |
| OPTICAL CALIBRATION KIT SCORPION | 16-SRS-OVK-ND | SRS-OVK |
| OPTICAL CALIB KIT FOR APR-5000 & | 16-APR-OPTICAL-KIT-ND | APR-OPTICAL-KIT |
| THERM CALIB KIT FOR APR-5000-XL | 16-APR-XL-CALKIT-ND | APR-XL-CALKIT |
| TESTER LOW RESISTANCE CONTINUITY | 35105-ND | 35105 |
| KIT LOW RESIST TESTER/CALIB UNIT | 35107DC-ND | 35107 |
In addition, the same information applies to SCS Calibration Certificates.
SCS NIST Calibration consists of
https://staticcontrol.descoindustries.com/Calibration.aspx
To reprint the SCS Calibration Certificate, click on this link
https://staticcontrol.descoindustries.com/Calibration-Certificate.aspx
SCS Calibration Pricing List
https://staticcontrol.descoindustries.com/Calibration-Pricing.aspx
Click Here for SCS parts that come with calibration
Check out this post for general calibration information!
