Needing female pins for Digikey part # 1734-1758-ND.
Will 1734-1331-ND fit this connector?
If not, will 1506-1059-ND fit, and if so when is it expected to be back in stock?
Thanks,
Greg B
The 1734-1331-ND would work.
0462-209-16141 TE Connectivity Deutsch Connectors | Connectors, Interconnects | DigiKey
If you need crimp tooling for that HDT-48-00
HDT-48-00 TE Application Tooling | Tools | DigiKey
Thanks for the info. Is it possible to solder those? (For one job, a $400 crimp tool is cost prohibitive)
Greg B
Still needing a reply.
The recommendation from Te is to crimp. We can’t deviate from the Supplier recommendation. Sorry.
Thanks for the information!
