Terminal
Hi i have order 2 connector # 1734-1228-ND AND # 1734-HDP24-24-23PT-ND
I search terminal to fit in this plug , I have already use number TXT126870254 terminal by Navistar and other TXT126870276 I search that terminal, can you help me about that :blush:
Welcome to the TechForum @Partsmanager
I am looking for the recommended contacts for these connectors.
PS.
I removed your web id as this is a public forum and is frequently scraped by bots
For the connector 1734-1228-ND, the contacts in the link below will work. You will need to select your AWG and plating for the contacts.
And for 1734-HDP24-24-23PT-ND the contacts in the link below will work. You will need to select your AWG and plating for the contacts.
Thanks for fast reply
