Hello my name is Emma, I am a college student and I had a question regarding the DigiKey Part Number
1568-1958-ND.
Is there a recommended battery that is around 5V that would work best with this board?
I am making a custom wireless macropad that has a small display screen and was not sure what battery would be best for this application.
emmashedden8
Thank you for contacting DigiKey , sorry I am not seeing that we have anything in a small size to offer for a battery pack for this are you looking for something that is rechargeable ? Here is a link for 6V with wire leads that are rechargeable .
Thanks Craig
Thank you Craig, but I was looking for something Li-Poly and rechargable. I need it to be small form factor as it will be in a Number pad structure.
P/N 1568-1958-ND would appear to be a breakout board for a USB-C connector: it provides no functions that the connector itself doesn’t.
As such, there’s little/no constraint on what sort of battery could potentially be “used with” that connector, and at the same time few/none that will give happy results if one doesn’t provide the necessary mechanisms to adapt it to the characteristics of USB.
A single Li-(whatever) cell is typical for small embedded devices these days. Pick one that fits the prevailing needs, then do some research on its proper care and feeding so that it doesn’t bite you.
