Registered and Non-registered users now have access to the new Price and Availability tool.
The Price and Availability tool allows you to check pricing and availability for a list of products with up to three quantities per line item. Lists can be downloaded or moved directly into a cart for purchase.
A link to this new tool will be available in the Resources drop-down menu in the header.
Clicking this link will take you to the upload page, where you will have three different options for adding parts to your Price and Availability list.
There are 3 ways to use this tool.
If you use the upload a file option, you will be taken to the mapping page where you will need to map at least a part number and one quantity to continue to the part list page.
You will then get the price and availability for the quantities you entered on the part list page broken into the appropriate packaging options.
You will also be able to change packaging types on products when there is more than one available.
Using the check boxes on the left-hand side of each line item you can choose lines to delete.
At the bottom of the parts list, you will also have the option to add another part to the list using manual entry.
Clicking the Edit icon next to a part number will give you the ability to change to a different part number while maintaining the same quantities and customer reference as the original part number.
You will also have to ability to download your parts list by using the download button at the top or bottom of the list. Clicking that will open a modal window that will allow you to choose what format you want to download the information in as well as what pieces of information you would like to have included.
You can also add your selected quantities to your cart by clicking the Add Selections to Cart button at the top or bottom of the list. This will open a modal window that allows you to either add the parts to your current cart, or create a new cart with just your selected quantities.
