We have several options for DIN rail mounts for the HWS-A Series power supplies from TDK-Lambda Americas Inc. located here: Power Supplies - External/Internal (Off-Board) | Accessories | DigiKey
Which one you will need depends on which power supply you have.
As seen below the HWS15A and HWS30A need the DIN01-A mount, the HWS50A uses the DIN02-A mount, and the HWS80A, HWS100A, and the HWS150A use the DIN03 mount.
Applicable Part Numbers
Digi-Key Part Numbers | ||
285-2258-ND | HWS100A24/RA-ND | 285-HWS100A12/RA-ND |
285-2257-ND | 285-HWS100A48-ND | HWS50A3/RA-ND |
285-2246-ND | HWS50A5/RA-ND | 285-HWS50A3-ND |
285-2255-ND | 285-HWS50A48/RA-ND | HWS30A3-ND |
285-2274-ND | HWS100A12/R-ND | 285-HWS150A3/RA-ND |
285-2262-ND | 285-HWS50A5/R-ND | 285-HWS100A48/RA-ND |
285-2260-ND | 285-HWS50A3/R-ND | HWS50A12/RA-ND |
285-2259-ND | 285-HWS100A48/R-ND | HWS50A15/RA-ND |
285-2252-ND | 285-HWS50A48/R-ND | HWS30A12-ND |
285-2256-ND | 285-HWS150A48/RA-ND | HWS50A48-ND |
285-2247-ND | HWS50A24/RA-ND | HWS100A15/RA-ND |
285-2264-ND | HWS30A5-ND | HWS150A15/RA-ND |
285-2251-ND | 285-HWS100A15-ND | 285-HWS150A5/R-ND |
285-2250-ND | 285-HWS150A48/R-ND | HWS30A15-ND |
285-2267-ND | HWS100A3/RA-ND | HWS30A48-ND |
285-2245-ND | HWS150A12/RA-ND | HWS150A48-ND |
285-2270-ND | 285-HWS100A5-ND | HWS15A48-ND |
285-2268-ND | 285-HWS100A3/R-ND | HWS15A5-ND |
285-2273-ND | HWS100A5/RA-ND | HWS15A3-ND |
285-2254-ND | HWS150A24/RA-ND | HWS15A24-ND |
285-2249-ND | 285-HWS150A3/R-ND | HWS15A15-ND |
285-2261-ND | 285-HWS150A12/R-ND | HWS150A12-ND |
285-2263-ND | 285-HWS100A12-ND | 285-2266-ND |
285-2271-ND | HWS150A5/RA-ND | HWS150A15-ND |
285-2272-ND | 285-HWS100A15/R-ND | HWS150A5-ND |
285-2269-ND | 285-HWS150A15/R-ND | HWS150A24-ND |
285-2265-ND | 285-HWS100A5/R-ND | HWS150A3-ND |
285-2253-ND | 285-HWS100A24/R-ND | HWS15A12-ND |
285-2248-ND | 285-HWS100A3-ND | HWS30A24-ND |
Manufacturer Part Numbers | ||
HWS50A-15/A | HWS100A24/RA | HWS100A12/RA |
HWS50A-12/A | HWS100A48 | HWS50A3/RA |
HWS15A-15/A | HWS50A5/RA | HWS50A3 |
HWS30A-48/A | HWS50A48/RA | HWS30A3 |
HWS150A-5/A | HWS100A12/R | HWS150A3/RA |
HWS50A-5/A | HWS50A5/R | HWS100A48/RA |
HWS50A-3/A | HWS50A3/R | HWS50A12/RA |
HWS50A-24/A | HWS100A48/R | HWS50A15/RA |
HWS30A-15/A | HWS50A48/R | HWS30A12 |
HWS30A-5/A | HWS150A48/RA | HWS50A48 |
HWS15A-24/A | HWS50A24/RA | HWS100A15/RA |
HWS100A-15/A | HWS30A5 | HWS150A15/RA |
HWS30A-12/A | HWS100A15 | HWS150A5/R |
HWS15A-5/A | HWS150A48/R | HWS30A15 |
HWS100A-48/A | HWS100A3/RA | HWS30A48 |
HWS15A-12/A | HWS150A12/RA | HWS150A48 |
HWS150A-15/A | HWS100A5 | HWS15A48 |
HWS100A-5/A | HWS100A3/R | HWS15A5 |
HWS150A-48/A | HWS100A5/RA | HWS15A3 |
HWS30A-3/A | HWS150A24/RA | HWS15A24 |
HWS15A-48/A | HWS150A3/R | HWS15A15 |
HWS50A-48/A | HWS150A12/R | HWS150A12 |
HWS100A-12/A | HWS100A12 | HWS100A-3/A |
HWS150A24/A | HWS150A5/RA | HWS150A15 |
HWS150A-3/A | HWS100A15/R | HWS150A5 |
HWS150A-12/A | HWS150A15/R | HWS150A24 |
HWS100A-24/A | HWS100A5/R | HWS150A3 |
HWS30A-24/A | HWS100A24/R | HWS15A12 |
HWS15A-3/A | HWS100A3 | HWS30A24 |
