Din Rail Terminal Block - 120V AC?
I am trying to find out if terminal Blocks like the following support/work with 120V AC:
DigiKey part : 277-1079073-ND
Manufactures part number: 1079073
Phoenix contact Double level Terminal block
Can I use such a terminal block to distribute 120V AC? if not is there a similar din rail mountable gang-able (>=4 connection points total) terminal block that would work?
The 277-1079073-ND terminal block can handle up to 600V and will accept 12AWG wire. It should work just fine.
