Searching for cable with pictured socket. or, just the socket.
WaterDocs,
Welcome to the Digi-Key technical Forum. I do have to apologize but I am unable to download and open your Zip file. Please provide us an image in a standard format such as *.jpg, *.png etc.
Thanks!
Must clarify that this plug is 3 blades, but the standard socket is likely 4 blades/prongs.
Automation Direct (pn: SC18-LS24-3) describes as: “MSUD valve form A 18mm”
Please take a look at this product and see if it will work for you.
| DIGI-KEY PART # | WM21612-ND |
| MANUFACTURER | Molex |
| DESCRIPTION | TYPE A 3P BLK |
| DATASHEET | Datasheet |
This type of connector can be found in this category.
Product Index>Sensors, Transducers>Sensor Cable - Accessories
Yes. This one doesn’t have an indicator LED, but is correct.
Thank you
I have found another product that you may be interested in. Please take a look at this one.
| DIGI-KEY PART # | 900-1210503237-ND |
its engineering part number would be E452P3N5001PC3H
The C3 at the end of the number indicates the following circuit diagram
Maybe this could work better for you.
