I am trying to build a pcb with a 4-way dip or selector switch that is capable of operating with a 500 VDC input. I can only find 3-way selector switches that work at this voltage. Any input would be appreciated.
Thanks!
Thanks!
Hi jeremy1,
I have not found any either. Perhaps you could use a standard dip switch to engage relays? One would need a lower voltage source available which the dip switch could tolerate and which could be used to drive the relays. Of course this would be much more complicated, but technically possible.
