Do you have second order filters?
do you have second order filters such as described here?
https://www.digikey.de/en/resources/conversion-calculators/conversion-calculator-low-pass-and-high-pass-filter
Welcome to the DigiKey TechForum. We do have the components for low and high pass filters. The calculator link is used to help narrow down components you may need for the filter in your application.
Hello a-bo,
The link you provided is great if you’re looking to customize and build your own filters. If you’re looking specifically for pre-made second order filters, you can find them in our EMI/RFI Filters section. Note that you will need to know your desired frequencies and packaging prior to choosing one.
If you’d like more context regarding the parameters in the EMI/RFI filters section, I highly recommend checking out the information in the Product Selection Guide:
Regards,
Klint
