“Can you help me if the model 4373-CT5-Q01-ND comes with a cable? Also, can you explain why it says it is a 24 VDC voltage? What current should it use, and does it come with the cable connection, or does it require a battery? Thank you.”
Supplier has more information here: https://www.auersignal.com/en/tower-lights/ct5/ct5/
No M12 signal cable is included with this part number.
This is to remain compatible with 24VDC industrial PLC applications.
Regards,
