To repair electronic devices stored only by isolating oxygen by vacuum sealing? Some electronic devices need to be energized regularly because of electronic capacitors and mechanical parts
Is it possible to preserve electronic devices for many years without oxidation or corrosion without needing a vacuum or isolating oxygen?
This is hard to say. I guess I would check the data sheets for storage life and if they have any recommendations. I would also follow the MSL and static recommendations and store per JDEC recommendations. You also have to be aware of your location and conditions the parts are being stored in. Saltwater, low humidity, high humidity are all things you need to be are of with the environment the parts are being stored in.
