What is the difference between DF13C-6P-1.25V(75) and DF13C-6P-1.25V(21), and can I sub (75) for (21)
Hello inga,
The number in parentheses means the type of plating and packaging. (21) is Tin plated embossed tape packaging. Seems the (75) is the obsolete number and type of packaging and plating combination isn’t available. These two connectors are basically identical in terms of form fit and function.
Regards.
Thank you so much for your reply!
