E3612S
------Question for E3612S.41.02 Please Put your question below------
Hi, I want to know the correct part number for above mentioned cable, in 1,000feet packing and red outersheath. According to my past experience, the right number should be E3612S.41.03 but it’s not exist.
The nearest one I found is E3612S.41.02-ND but in white outersheath.
Please help to advise how to obtain the correct part number.
Thanks a lot/Tommy Tse
Hi @tommytseys ,
Welcome to DigiKey TechForum and thanks for your inquiry.
Are you looking for E3612S.41.03?
Thank you.
Hi Angus,
Yes the cable number is correct but I cannot find the DigiKey part number which only has 500feet but not 1000feet.
Please kindly check and advise.
Thanks/Tommy
The part number that Angus links to is for 1000ft of E3612S.41.03. When you click on the linked part it should open to the correct product page.
I want to place order for this item but I can’t find the said DigiKey part number ………. Can you help?
Thanks!
Furthermore, I can only got E3612S.41.3 with 50 and 100 feet length, but 1000 feet not exist.
E3612S-1000-ND is the DigiKey P/N for a 1000’ length of the desired cable material with red jacket, similarly E3612S-500-ND is the DigiKey P/N for a 500’ length of the same material.
Hi Ricky, thanks a lot for your reply but I cannot find the said DigiKey part number when order. Please help to clarify, thanks!
I got it now, sorry to trouble you and thanks a lot!
