Alternate Lengths for Hook-Up Wire/Ribbon Cable
We get many requests for alternate lengths of hookup wire and ribbon cables. One trick for finding these is to use the “base” of the DigiKey part number. For example:
MTF1007-100-ND is 100 feet (as indicated in the -100 portion of the part number)
If you only search the base part number of MTF1007, you will return 6 results in different lengths.
This may not work in every scenario, but it is worth looking into.
