ECODRIVE 361/S Replacement
The following is for informational purposes only. Please verify that the specifications meet your requirement and check the manufacturer’s datasheet before using any product as a replacement.
ECODRIVE 361/S is an LED driver that we do not carry, but have gotten request for. Based on the markings, I was able to confirm the following specs:
Current Output: 150-1400mA (settable)
Power Output: 30W max
Voltage output: 2-55VDC
Based on these, it seems like our best option is going to be part number 4797-SMT-M-040CM-ND from Smarts Electronic & Technology. It should meet or exceed the relevant ratings but as always, double check the specifications before using this as a replacement.
