This LED driver is listed obsolete in our system. Here are some of the key specifications of the part:
Type: Constant Current
Voltage - Input (Min): 120VAC
Voltage - Input (Max): 277VAC
Voltage - Output: 48 ~ 142V
Current - Output (Max): 530mA
Power (Watts): 75W
With these specifications, we can find a possible substitute that has an active status.
These options can be considered similar to the original product - LED Drivers. These will have a similar power rating of 75W. There are multiple different output voltage ranges for these drivers, but they fit within the original range of the obsolete driver. This will depend how much voltage you would be using on the original voltage range. The output current on the recommended drivers are larger in max current, but will only supply the current needed, such as the 530mA.
Please also review the datasheets to make sure these will work for the application.
