The Thomas Research PLED150W-042-C3500-D3 is obsolete. I am looking for a replacement driver. Any suggestions? Thank you.
the closes I find is part number AMER160-48340Z
3.4a
voltage 15-48v
Hello shelley,
Thank you for your inquiry. Above and below options may all work, depending on the actual LEDs and if you need dimming feature.
Below is the active newer version but is non-stock with high minimum order quantity, along side the best stocking cross that I’ve found. Please review datasheet specifications as there are some slight differences.
Click here for 1866-2375-ND | 1121-1381-ND
If you know the actual voltage of the LEDs, below may be a few other options to consider:
Click here for all possible options.
-Please let us know if you have any further questions
Summary
PLED150
93056692
Q10692416
Q9588071
1121-1381
93056691
hubbell
Thank you for looking into this for me.
Sincerely,
Shelley
