Looking for the leakage current for EMZA250ADA470MF61G
Trying to see if it is a cross to UCD1E470MCL1GS which has 11.8uA of leakage current at 2S.
0.01CV works out to the 11.75uA figure; the specification would appear identical for both, despite the datasheet for one not showing tabulated values.
It’s not a critical parameter in most instances where the use of such devices is appropriate, and the spec likely represents an industry norm for tolerable leakage levels more so than actual device performance.
